Spoon Chassis Parts
As found in the link provided below, has anyone used the Spoon springs, and if so, do you favor them over anything else? What shock to use them with, and what about the stock shocks? Can you get away with using them with the stock shocks without ill affects?
http://www.inlinefour.com/suscomandac1.html
If your looking for a really nice spring and shock set up to use, I suggest you run the Espelir and Koni yellow combo because it is fairly cheap and is a very good bang for the buck type ordeal. The espelir spring itself lowers the car about 1.3 inches front and rear, and by setting the Koni yellow shock on the lowest perch, you are able to drop the car another .5 inches. A fairly moderate 1.8 drop with adjustable dampening is not that bad at all.
But whenever you get tired of this combo, switch out the spring and run some adjustable Ground Control coilover sleeves with the Koni Yellows. Track guys love this set up and some even say, these combo is a lot better than the "true" full JDM coilovers they have on the market.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OBSeRiouSo »</TD></TR><TR><TD CLASS="quote">If your looking for a really nice spring and shock set up to use, I suggest you run the Espelir and Koni yellow combo because it is fairly cheap and is a very good bang for the buck type ordeal. The espelir spring itself lowers the car about 1.3 inches front and rear, and by setting the Koni yellow shock on the lowest perch, you are able to drop the car another .5 inches. A fairly moderate 1.8 drop with adjustable dampening is not that bad at all.
But whenever you get tired of this combo, switch out the spring and run some adjustable Ground Control coilover sleeves with the Koni Yellows. Track guys love this set up and some even say, these combo is a lot better than the "true" full JDM coilovers they have on the market. </TD></TR></TABLE>
not better than Amuse
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Projekt »</TD></TR><TR><TD CLASS="quote">Not better than Spoon/Swift.</TD></TR></TABLE>
I know the Spoon springs will bolt on and work, my question is will the stock shocks be effective enough? I know they're pretty good from the factory, but I don't know HOW good.
Spoon/Swift?
Are we talking Spoon spings and Swift shocks? Or the other way around?
I've seen the Amuse coiovers, BTW. Very nice pieces, how much are they? I haven't yet had the opportunity to do much research yet.
Spoon/Swift?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ntensehonda »</TD></TR><TR><TD CLASS="quote">
Spoon/Swift?
Are we talking Spoon spings and Swift shocks? Or the other way around?</TD></TR></TABLE>
both are springs (i think)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">
I've seen the Amuse coiovers, BTW. Very nice pieces, how much are they? I haven't yet had the opportunity to do much research yet.</TD></TR></TABLE>
Like .... VERY expensive LOL
Spoon/Swift?
I had Neuspeed (the lowest drop available from a spring alone, I believe) and stock shocks for about 10K miles. I thought it pretty much handled like stock. It did reduce body roll fairly dramatically though. Now I've got Tein Flex and wish I would have just bought coilovers from the beginning.
Spoon/Swift?
I've seen the Amuse coiovers, BTW. Very nice pieces, how much are they? I haven't yet had the opportunity to do much research yet. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gabspeed »</TD></TR><TR><TD CLASS="quote">
Like .... VERY expensive LOL </TD></TR></TABLE>
Spoon shocks, Swift springs.
Amuse Hi-Tech dampers are about $3600.
Spoon/Swift?
shoa's with swift
Amuse Hi-Tech dampers are about $3600. </TD></TR></TABLE>
Arnt the AMUSE just re valved billsteins with better springs? Their still amazing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3vilMonkey! »</TD></TR><TR><TD CLASS="quote">Not better than aragosta</TD></TR></TABLE>
My future coilovers if I ever get money, but not better than Motons
shoa's with swift
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco »</TD></TR><TR><TD CLASS="quote">
You are correct, they are Bilsteins.
Moton Club Sports.
</TD></TR></TABLE>You are correct, they are Bilsteins.
Moton Club Sports.
Chillinit
Nov 25, 2009 11:11 AM
EBPSI
Nov 24, 2002 07:06 AM
snake01
May 20, 2002 03:51 PM
shpae
Dec 17, 2001 10:18 PM
