Cams, Compression Ratio and Idle
Old May 12, 2002 | 05:19 AM
Regular Series's Avatar
Default Cams, Compression Ratio and Idle
I have heard that you need to bump compression in order to maintain idle quality with hotter cams. My question is, why? How is it that a higher compression ratio will smooth out idle with hot cams? Jus' wonderin'....
Old May 12, 2002 | 08:56 AM
earl's Avatar
Default Re: Cams, Compression Ratio and Idle (risingson77)
I don't believe that is true but it may have happened to a couple of people because of their situation. Say if you had a tired motor which you rebuilt with higher c/r and new rings, actually the sealing of the new rings gave it a smoother idle.
Old May 12, 2002 | 01:03 PM
Default Re: Cams, Compression Ratio and Idle (earl)
Interesting...yeah, I'd wondered how that worked...thanks!
Teamdiesel
Jan 16, 2006 07:35 PM
KeyserSoze
Oct 20, 2005 08:36 PM
bboy21385
18
Dec 4, 2004 05:39 AM
Renegade
Aug 20, 2004 08:16 AM
