mugen axle hitting swaybar link. bad? are there any kind of sway bars that doesnt stick out like thi
Old Dec 14, 2006 | 09:19 PM
pli's Avatar
pli
Default mugen axle hitting swaybar link. bad? are there any kind of sway bars that doesnt stick out like thi
you see how the axleback is touching the sway bar link? can this affect the sway bar sooner or later? will it break something off?
are there any sway bars that doesnt curve up like that? or are they mostly like that?
Old Dec 14, 2006 | 10:24 PM
JDM KID 510's Avatar
That do not look like a axles too me. It look like it hitting the exhaust pipe. Try to push up the exhaust pipe up more, Cause it seen their a lot space between the chassic and the pipe.
Old Dec 14, 2006 | 11:34 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
Default Re: mugen axle hitting swaybar link. bad? are there any kind of sway bars that doesnt stick out like
i think the sway may be installed upside down
Old Dec 14, 2006 | 11:43 PM
chrisw85's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rukawa1one &raquo;</TD></TR><TR><TD CLASS="quote">i think the sway may be installed upside down</TD></TR></TABLE>
winner!
Old Dec 15, 2006 | 05:52 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisw85 &raquo;</TD></TR><TR><TD CLASS="quote">winner!</TD></TR></TABLE>
Old Dec 15, 2006 | 06:05 AM
92ehatch's Avatar
lol upside down FTL!!!!
easy fix.
Old Dec 15, 2006 | 06:21 AM
gabebauman's Avatar
Yup...flip it over.
Old Dec 15, 2006 | 06:54 AM
sicones's Avatar
mugen axle
Old Dec 15, 2006 | 07:19 AM
maxxd97's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gabebauman &raquo;</TD></TR><TR><TD CLASS="quote">Yup...flip it over. </TD></TR></TABLE>
Old Dec 15, 2006 | 07:43 AM
NIKE SB'd's Avatar
haha
Old Dec 15, 2006 | 11:15 AM
pli's Avatar
pli
Default Re: (JDM Kid 510)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Kid 510 &raquo;</TD></TR><TR><TD CLASS="quote">That do not look like a axles too me. It look like it hitting the exhaust pipe. Try to push up the exhaust pipe up more, Cause it seen their a lot space between the chassic and the pipe.</TD></TR></TABLE>
i've tried pushing the exhaust pipe up. thats the most it can go.
Old Dec 15, 2006 | 11:20 AM
SilentEdge's Avatar
Batpool
Default Re: (pli)
The sway bar is upside down. Remove, flip, reinstall, no more problems.
Old Dec 15, 2006 | 11:25 AM
pli's Avatar
pli
Default Re: (SilentEdge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilentEdge &raquo;</TD></TR><TR><TD CLASS="quote">The sway bar is upside down. Remove, flip, reinstall, no more problems.</TD></TR></TABLE>
has anyone taken a swaybar off before? i believe i have to use an impact gun to take it off right? or should i just take it to a shop?
Old Dec 15, 2006 | 11:28 AM
sicones's Avatar
Default Re: (pli)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pli &raquo;</TD></TR><TR><TD CLASS="quote">
has anyone taken a swaybar off before? i believe i have to use an impact gun to take it off right? or should i just take it to a shop?</TD></TR></TABLE>
it should take a regular honda street mechanic about 15 minutes to fix, do you own a socket set?
Old Dec 15, 2006 | 11:35 AM
NIKE SB'd's Avatar
Default Re: (pli)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pli &raquo;</TD></TR><TR><TD CLASS="quote">has anyone taken a swaybar off before? i believe i have to use an impact gun to take it off right? or should i just take it to a shop?</TD></TR></TABLE>
haha again. just take it of with hand tools man.
Old Dec 15, 2006 | 11:36 AM
instructor74's Avatar
Default Re: (sicones)
AHHHH Huston we have a problem easy fix just a few min and 14mm socket if I remember right.
Old Dec 15, 2006 | 11:40 AM
grayegcivic's Avatar
as long as you have the tools and jack....i don't see why you have to take it to a mechanic...
Old Dec 15, 2006 | 12:10 PM
BlueIntegraBoy's Avatar
Yup, upside down. Unbolt it from the brackets and endlinks. Rotate the bar 180 degrees, and bolt everything back.
Old Dec 15, 2006 | 02:22 PM
pli's Avatar
pli
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Yup, upside down. Unbolt it from the brackets and endlinks. Rotate the bar 180 degrees, and bolt everything back. </TD></TR></TABLE>
done! took me nearly an hour. my exhaust still sounds like its running w/o a cat. im not sure if its normal. cause i hear noises coming out of the end of the exhaust where it connects to the midpipe. does anyone know if i can put more than one gasket in between the axle and the midpipe?
Old Dec 15, 2006 | 02:42 PM
Harryflores's Avatar
Default Re: (NIKE SB'd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NIKE SB’d &raquo;</TD></TR><TR><TD CLASS="quote">haha</TD></TR></TABLE>
x2
TheTealHatch
Suspension & Brakes
Apr 4, 2007 10:20 PM
Shizznaz
Suspension & Brakes
Jul 20, 2005 04:20 PM
Si Arn
49
May 3, 2004 09:59 PM
JDM_Type-R
Mar 22, 2004 09:34 PM
wdskuk
Sep 5, 2003 10:47 AM
