EK rear camber kit on an EG?
Old Dec 14, 2006 | 08:48 PM
clutch1515's Avatar
Default EK rear camber kit on an EG?
Doable? found a deal on one so I'm wondering if it'll work
Thanks
Old Dec 14, 2006 | 08:57 PM
verycleanhatch's Avatar
Default Re: EK rear camber kit on an EG? (clutch1515)
im not sure(ek camber kit on eg) but you can just use some washers and a longer bolt to correct your camber.
Old Dec 14, 2006 | 09:00 PM
clutch1515's Avatar
I'm confused... I can correct it woithout the camber kit or a new bolt with the camber kit?
Old Dec 14, 2006 | 09:32 PM
clutch1515's Avatar
Some one please help me. Got to get this soon
Old Dec 15, 2006 | 03:58 PM
pat92si's Avatar
Default Re: (clutch1515)
you can fix the rear negative camber by using washers and a longer bolt. theres really no need for a rear camber kit so you can save the $$
Old Dec 15, 2006 | 04:37 PM
CivicSiRX's Avatar
it will fit fine.
1995Civiccx
Jan 19, 2008 08:19 PM
blk94gsr
Suspension & Brakes
Feb 15, 2006 08:49 AM
QB21
Feb 8, 2006 01:50 PM
fafsa
Apr 6, 2005 03:40 PM
Takeoff
Aug 11, 2002 01:08 PM
