Engine compression 160psi?? WTF?
Old Dec 14, 2006 | 08:29 PM
Bay Area Baller's Avatar
Default Engine compression 160psi?? WTF?
Ok heres the deal. We rebuilt a B18c1 about 6 months ago. It boggled us that the compression was only 175.
Now were are messing with the same motor. We added some upgrades, AND put new rings in AGAIN. And the compression is at 160??
Heres the specs
Cylinder bore 81.5 mm (+.003)
pistons 81.5mm
end gap on rings
Am I missing something? How the hell can this happen??? TWICE?
Old Dec 16, 2006 | 07:45 AM
92hondalude's Avatar
Default Re: Engine compression 160psi?? WTF? (Bay Area Baller)
how about the valves. are they seating correctly?
no scratches in the cylinder wall are there?
Old Dec 16, 2006 | 11:04 AM
vtec2nv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bay Area Baller &raquo;</TD></TR><TR><TD CLASS="quote">Ok heres the deal. We rebuilt a B18c1 about 6 months ago. It boggled us that the compression was only 175.
Heres the specs
pistons 81.5mm
end gap on rings
how many miles on the motor?
Old Dec 16, 2006 | 01:33 PM
A.E Motoring's Avatar
Default Re: Engine compression 160psi?? WTF? (vtec2nv)
cold motor? cranks number of times? ran it for the rings to sit?
Old Dec 16, 2006 | 01:38 PM
AllMTRWH0R3's Avatar
What mod did you do to it? since you are stating you changed something up in the motor. Also psi in a cylinder is not always a bad thing. If they are all even it's should be fine. Now if you changed something that will change the static compression of the motor but all psi in each cylinder corresponds with all other's I dont see a problem ( then again there is not much to go on in the above mentioned post)
Give us more info, since I hate being a e-mechanic
Old Dec 17, 2006 | 02:53 AM
ITRnorway's Avatar
was the throttle wide open?
Old Dec 17, 2006 | 12:19 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (ITRnorway)
How was the compression test done? did you remember to disable the fuel system?
Bay Area Baller
Dec 16, 2006 02:45 PM
kornerk12
Jan 5, 2006 07:20 PM
street dreams
Nov 26, 2004 12:52 AM
mjrage
12
May 28, 2004 03:20 PM
311
Dec 14, 2002 12:18 PM
