I just got my buddyclub exhaust in and ...
Old Dec 14, 2006 | 07:26 PM
92integracer's Avatar
Default I just got my buddyclub exhaust in and ...
I just got my buddyclub spec II in for my crx and this does NOT look like a 60mm exhaust. In fact the innerpipe diameter is 2in. It also seems to not have a muffler but a tip on it. Anyone care to comment on why it seems small?
Old Dec 14, 2006 | 07:27 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: I just got my buddyclub exhaust in and ... (92integracer)
Measure it and double check.
Also is the 60mm OD or ID adverstised?
Old Dec 15, 2006 | 10:17 AM
outter diameter is 50mm
Old Dec 15, 2006 | 10:19 AM
Ass$nyper's Avatar
Default Re: (92integracer)
Wow, yea that doesn't sound right where did you get it from ?
Old Dec 15, 2006 | 10:23 AM
gator88's Avatar
Default Re: (Capt. Blonde Beard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Capt. Blonde Beard &raquo;</TD></TR><TR><TD CLASS="quote">Wow, yea that doesn't sound right where did you get it from ?</TD></TR></TABLE>
sounds like an ebay butt raping. i hope not so this man can return it
Old Dec 15, 2006 | 11:07 AM
I want to clarify, I don't have a something flexible to measure with so I took a ruler and measured at an opening the outter diameter and not around the pipe
Old Dec 15, 2006 | 11:15 AM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integracer &raquo;</TD></TR><TR><TD CLASS="quote">I want to clarify, I don't have a something flexible to measure with so I took a ruler and measured at an opening the outter diameter and not around the pipe</TD></TR></TABLE>
Run to the hardware store *Lowes or HD I own stock in both so what ever one *
get something to measure this way incase there is a problem you have a sure measurement and hopfully you just got a badmeasurement and its all good.
Old Dec 15, 2006 | 11:22 AM
i just realized wouldn't measuring around the pipe cause for a lot bigger measurement than 60mm. I used a string and was measuring over 100mm.
Old Dec 15, 2006 | 11:24 AM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integracer &raquo;</TD></TR><TR><TD CLASS="quote">i just realized wouldn't measuring around the pipe cause for a lot bigger measurement than 60mm. I used a string and was measuring over 100mm.</TD></TR></TABLE>
the OD is 100mm and inner is 50mm.
weird...
Old Dec 15, 2006 | 11:51 AM
sorry I think you miss understood what I said, this is taking string and putting it all the way around the pipe, which doesn't give you the diameter. Can anyone confirm that the buddy club spec II for a crx is in fact 60mm?
Old Dec 15, 2006 | 01:05 PM
HamiltonRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Capt. Blonde Beard &raquo;</TD></TR><TR><TD CLASS="quote">the OD is 100mm and inner is 50mm.
weird...</TD></TR></TABLE>
no, i cant believe im reading this.
DIAMETER IS ACROSS THE OPENING OF THE PIPE, ID is inside, OD is outside.. When you use a string and measure around this is CIRCUMFRENCE(sp?) not diameter! Jebus people!!!
If a exhaust had 100mm OD and 50mm ID it would be a thousand pounds!
Old Dec 15, 2006 | 01:56 PM
gator88's Avatar
Default Re: (HamiltonRex)
if it is 100 mm circumference then.. circumference equals pie (approx 3.14) x diameter. so... this means 100/3.14 = outer diameter of approx 31.85mm. now, this is if you wrapped the string around the pipe. 1mm = .0393700787 inch, your pipe has an outer diameter of 1.25 inch. i think you measured wrong or were sent a pea shooter. you tell me. (no i didnt know what a mm equaled off the top of my head, but google helped. i know the rest, i do it all the time in hs for these damn ASVAB (military) tests we always take)
Old Dec 15, 2006 | 01:59 PM
s10cky's Avatar
Default Re: (gator88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gator88 &raquo;</TD></TR><TR><TD CLASS="quote">were sent a pea shooter</TD></TR></TABLE>
Old Dec 15, 2006 | 04:36 PM
this is not the point, I know i measured the circumference (by the way it was just a rought estimate since I knew it wasn't important anyway) and not the diameter, I already mentioned this in the post. the point of this thread was to figure out why the inner diameter of this exhaust is 2in when I thought this exhaust was suppose to be 60mm!!
Old Dec 15, 2006 | 05:40 PM
CrX-WoRlD's Avatar
hey..i got one this week also but from buddyclub usa directly..i must take out the box but i'm gonna tell you the real measurements tonight or tomorrow!!
Old Dec 15, 2006 | 06:36 PM
civhatch90's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integracer &raquo;</TD></TR><TR><TD CLASS="quote">this is not the point, I know i measured the circumference (by the way it was just a rought estimate since I knew it wasn't important anyway) and not the diameter, I already mentioned this in the post. the point of this thread was to figure out why the inner diameter of this exhaust is 2in when I thought this exhaust was suppose to be 60mm!!</TD></TR></TABLE>
how about you call whoever sold it to you and ask them that?
Old Dec 15, 2006 | 06:41 PM
djphonics's Avatar
Yeah circumference is important, considering that it is directly related to the diameter. Measure again either that, or the diamter (with calipers).
Old Dec 15, 2006 | 08:21 PM
CrX-WoRlD's Avatar
the center section mid-pipe is 2 in like you said......but don't forget it's a free flow exhaust so 2 in is enough...well i think.........ordered through buddyclub usa..so.....
Old Dec 15, 2006 | 09:04 PM
STREETWERKZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">
If a exhaust had 100mm OD and 50mm ID it would be a thousand pounds!</TD></TR></TABLE>
Old Dec 16, 2006 | 12:40 AM
Fobtions's Avatar
Default Re: (STREETWERKZ)
the EF spec II is smaller than the EG apps.
most sellers recyle the same old info and say its 60.
Old Dec 16, 2006 | 10:02 AM
So it really is a 50mm exhaust. Tlhat is disappointing because I was eventually going to turbo my ls motor and now I have a F-ing 2in exhaust!
Old Dec 16, 2006 | 10:03 AM
Is there an exhaust for a crx that is actually 60mm? How about RS*R or invidia?
Old Dec 16, 2006 | 10:04 AM
Fobtions's Avatar
im sure u can sell it , ive gotten many offers for mine.
98exturd
Jun 4, 2008 10:14 AM
scorp965
Acura NSX
Dec 18, 2006 07:36 PM
zexifiedlude
Nov 30, 2005 09:39 AM
stRodda
Aug 16, 2003 04:29 PM
90Hatch
Apr 10, 2003 07:38 AM
