HELP
Recently ive been driven my car and having problems.
Ok so i drive around and my car will try to die and i have to play with the gas pedal for it can keep on runnin sometimes it works other times it just does not.
So what i was told to do is replace my fuel filter and i did, and i still had the same problem i tried even starting the car with one of the hoses disconnected and no fuel was pumped out. Then i was told to check my relay and i did and everythin seemed intact on the solder point just in case i removed and resolder eveything. And my problem still continued. So i checked and i went to junk yard to find some fuel pumps, then i go ahead to replace the fuel pump so i go ahead and i remove it and replace it and i still had the problem until i ran direct current to the pump and then i saw my pump was workin great. I then remove one of the hoses from the fuel filter to see if im gettin fuel then it starts to work i see fuel.
Now i connect eveything back together and i try to start the car will my engine does turn and my car start but dies quickly i really need help on this cuz i need to take my car to my dads shop so i can drop in my new engine
i check the codes it flashin once for the o2 sensor on the header i replaced
and throwing code 6 then i replaced my temp sensor
and i really dont know wat else is wrong with the car
it might of been your tps sensor.... or maybe you just needed a tune up... i had the same problem with my crx... and after a while of playing with the gas i just ajusted the cable so that it would not turn of and it worked... i have no clue what it was...
