Car sputters when starting off the line with <4 gallons in the tank.
So pretty much as the title says, my car runs like a champ until it gets down to 4 gallons or so, and then it sputters when it tries to get off the line, but runs fine when it gets going. What should I check? Fuel line? Spark plugs? Injectors? Thanks for the help
non baffled tank + low fuel+ sudden movement = EF
I have this problem as well but only autocrossing when taking hard turns if I have less than like 3 gallons. I have talked to others that auto-x with the same car. seems like almost all have this problem
em Dot
Aug 18, 2006 01:07 PM
