strange b18c5 problem
Well It started when i was doing my routine maintenance on the motor, i changed the spark plugs, oil ect. even did a comp test for fun were i got 210 across the board. then i removed the valve cover for a friend to look at my cams and what not when i noticed on the number one valves one of my titanium retainers looks to have broke in the middle and slid down in to the spring sumhow, the motor showed no signs of this before hand and after a while i got the ***** to start it back up and it starts/drives as if nothing is wrong. but i am very nervous about this but at the same time amazed the motor runs with no problems. id like input or suggestions on what to do or not to do.
Btw it is a 98 b18c5 with 88k
jun type 2 cams with jun ti valve springs and retainers/cam gears
port and polish. rc 440's ect ect
you need a better picture, man. if you do indeed have a problem with a retainer, it needs to be fixed immediately, and DONT START THE ENGINE. now, you're not just lookin at the little space between the 2 valve locks, are you??
Well when it was tuned, the fuel cutoff was set at 9,600 and still making power.
so i guess that is your over reving.
How long will it stay like this? i dont relly have the time to take the car in right now.
But when i do, i think i am going to repace the hole set not just that one.
sorry thats the only pic i can get at the moment. Describe what it whould look like if that was it. it seems like i can just see the top of the spring but no ret. that one looks diffrent then all the rest.
And the car has been drove to my house since this and it has been the same.
Well the only thing stock on the motor is the block,pistons. but i treat this car like my kid as i bet most of you do. so the car is babied and has only seen past 9k a handfull of times. but that is not the issue at hand -
Rent an econobox car for a few days and have a qualified tech(or at least a buddy who has done a cam swap before) take a look at the car...may cost you a lot less in the long run.
If you end up trashing a retainer...it can cause some real havoc in the top-end (and worst case drop a valve)...it would ruin your day real quick-
Cheers!
Cheers!
Did you eat paint chips as a kid?
your picture is still not working
DO NOT DRIVE OR START THE CAR until you replace all the retainers and possibly the keepers as well.
You may also have some bent valves...yes they may have somewhat straightned themselves out, but they will eventually fail and then you will be in a world of hurt.
no i did not eat paint dumbass.
it wont let me make it any bigger. and the car has already been strated/drove.
my dad moved it this morning, he said it seemed fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spunkster »</TD></TR><TR><TD CLASS="quote">Did you eat paint chips as a kid?
lol!
if that retainer looks like I think it looks, you are one lucky SOB. host it somewhere else so we can ALL see it WITHOUT having to log into that stupid site to view the larger image.
lol!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99em1_sir »</TD></TR><TR><TD CLASS="quote">Well when it was tuned, the fuel cutoff was set at 9,600 and still making power.
But when i do, i think i am going to repace the hole set not just that one. </TD></TR></TABLE>
l m a o, id REALLY like to see that dyno
[QUOTE=.m a c a]
l m a o, id REALLY like to see that dyno[/QUOTE
whould u REALLY like too?
if i still had it then sure u could see it. 210 whp / 177 fpt
and btw if u wana hate take it sumwere else
