need help choosing a tranny!
Old Dec 14, 2006 | 12:25 PM
efinitup's Avatar
Default need help choosing a tranny!
Hey need help choosing a tranny for my 89 ef with a d16y8. It is the canada model on the title is has model: as UCV????? No idea what that means. I currently have a 89 trans and just wanna know should i keep this trans or get a better one if there is a better d series trans. I'm not too fimilar with the d series. This is my 1st "D. Thanks in advance."
Old Dec 14, 2006 | 12:26 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: need help choosing a tranny! (efinitup)
Better how?
What are you doing with the car?
Old Dec 14, 2006 | 12:43 PM
efinitup's Avatar
Default Re: need help choosing a tranny! (Capt. Blonde Beard)
Turbocharging! it.
Old Dec 14, 2006 | 12:48 PM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efinitup &raquo;</TD></TR><TR><TD CLASS="quote">Turbocharging! it.</TD></TR></TABLE>
ok...
that still leaves what are you doing with it?
what kinda power will you be making
is it for drag auto X daily
Old Dec 14, 2006 | 07:18 PM
efinitup's Avatar
Well pretty much drag as well as my weekender! Lookin to get it in the 12's at the very lease, I like the fact that it is the underdog of the honda motors besides the d15 non vtec! Hp range desired is 250 - 330 if possible. Again boosted. Basically i want a cable tranny with decent acceleration! Or if the best out there is a hydro im willing to spend a bit to swap to hydro.
Old Dec 14, 2006 | 07:19 PM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efinitup &raquo;</TD></TR><TR><TD CLASS="quote">Well pretty much drag as well as my weekender! Lookin to get it in the 12's at the very lease, I like the fact that it is the underdog of the honda motors besides the d15 non vtec! Hp range desired is 250 - 330 if possible. Again boosted. Basically i want a cable tranny with decent acceleration! Or if the best out there is a hydro im willing to spend a bit to swap to hydro.</TD></TR></TABLE>
okie dokie so will you be using slicks and street tires or just one kind and what sizes?
Old Dec 15, 2006 | 07:36 AM
efinitup's Avatar
no slicks yet will just be using street tires 15in kumho
Old Dec 15, 2006 | 07:41 AM
Loserkidwac's Avatar
I was a fan of the D Si trans that was in my 91 CRX Si and I'm pretty sure that would be a good choice for your apps but listen to th capt. he knows better than I do
Old Dec 15, 2006 | 10:05 AM
Ass$nyper's Avatar
Default Re: need help choosing a tranny! (Loserkidwac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loserkidwac &raquo;</TD></TR><TR><TD CLASS="quote">I was a fan of the D Si trans that was in my 91 CRX Si and I'm pretty sure that would be a good choice for your apps but listen to th capt. he knows better than I do </TD></TR></TABLE>
ty ty sir, but you are right I would agree that a Si tranny would work well.
I know somewhere on the net is a gear calc for D series, if you really want to be ****, you might want to try it out
Old Dec 15, 2006 | 02:04 PM
Dave_Darling's Avatar
The Si trans is nice and low, but if you really want more torque being put down on the pavement, combine the ZC gears with the Si ring and pinion! For some odd reason, they put very low gears in the ZC transmissions, but used the same R&P as the DX models. The end result was overall ratios that were almost the same as the Si ratios. The Si, on the other hand, had taller gears (same as in the DX!) but a shorter R&P, making for overall shorter gearing than the DX; and almost the same as the ZC.
Put the low Si R&P together with the low ZC main gears, and you get about the lowest gearing you can get!
Keep the Si 5th, because there's no way you'll use 5th in a drag race and the Si one will keep you from having to run 4500 RPMs just to keep up with freeway traffic. (Only 3500...)
--DD
Old Dec 15, 2006 | 05:48 PM
efinitup's Avatar
Default Re: need help choosing a tranny! (Dave_Darling)
DD
AWESOME MAN. HAS THIS BEEN DONE BEFORE? ANd how would i know what tranny i have. Well what code to look out for?
Old Dec 18, 2006 | 03:45 PM
It's been done a few times before. You may be able to turn up "effin motorworks" on Google or some such; they've done at least a few. They're in TX; maybe not that far from you....
Not sure how to tell which trans you have. Some people say there are different codes stamped on the outside of the trans, others say you have to put it in gear and spin the input shaft and see how much the output flanges turn...
--DD
RyanG
Feb 29, 2008 06:25 AM
1FSTNDN
Nov 29, 2006 04:13 PM
xJDMCx
11
Jun 4, 2006 01:59 PM
Hoppa
Sep 12, 2005 01:33 PM
Blanket Jackson
Jan 12, 2005 02:02 PM
