Gates "Sport" timing belt?
Old Dec 14, 2006 | 10:32 AM
d16dcoe45's Avatar
Default Gates "Sport" timing belt?
Has anyone seen or used these Gates "Sport" timing belts? They are blue in color and supposed to be equivalent to Toda or PE belt--the only thing is they have them available for d16 (gat-t145rb) which is interesting. Also, they are alot more reasonable than the Japanese race belts--I think the Gates are around $85. I want to look into this next time I have to replace my belt--any experience? I know alot of people are going to say stock is the best--but for people with stiff springs and big cams, is stock really better than one of these supposedly stronger aftermarket belts?
Old Dec 14, 2006 | 10:42 AM
xDicktonesx's Avatar
Default Re: Gates "Sport" timing belt? (d16dcoe45)
i havent heard anything of the such but im bumping in hopes that you get your info
Old Dec 14, 2006 | 11:12 AM
d16dcoe45's Avatar
Default Re: Gates "Sport" timing belt? (xDEFTONESx)
thank you. I just think its neat because none of the other companies (Toda, Greddy, PE) make a d-series application--and Gates does--on the site is says the typical stuff--"300% stronger, stretch resistant" etc.--I know Gates is an OE supplier so its probably equally as good as the OEM belt.
Old Dec 14, 2006 | 01:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16dcoe45 &raquo;</TD></TR><TR><TD CLASS="quote">thank you. I just think its neat because none of the other companies (Toda, Greddy, PE) make a d-series application--and Gates does--on the site is says the typical stuff--"300% stronger, stretch resistant" etc.--I know Gates is an OE supplier so its probably equally as good as the OEM belt.</TD></TR></TABLE>
what about the B series?
its sad that the blue/red is what sells most of these atermarket belts. i want a camoflauge one
Old Dec 15, 2006 | 04:58 AM
d16dcoe45's Avatar
Oh--of course they make b-series too. I was just mentioning the d, because none of the other "sport" belts make a d-application.
Old Dec 15, 2006 | 06:01 AM
Pondus's Avatar
Interesting info, especially that they are $100 less than PE/Toda. Will have to look into this when I need a new belt.
Old Dec 15, 2006 | 06:46 AM
NA_B18C1's Avatar
i seriously wouldn't spen 200 on a aftermarket timing belt..i rather use a brand new OEM belt..i brother inlaw has a greddy timing belt and just after 1000 miles that belt looked like SH*T with color all faded and junk
Old Dec 15, 2006 | 09:07 AM
d16dcoe45's Avatar
Default Re: (NA_B18C1)
That is part of the allure--these aren't $200--they are around $85--more than OEM--but perhaps better than oem for people with big cams & heavy springs. Well, a light color belt will start to get dirty and look ugly after a bit--the only reason you can't tell on the oem belt is because its black--guarantee it would look just as dirty.
Old Dec 15, 2006 | 09:12 AM
Anti-Drama Queens's Avatar
if im thinking of the right gates brand u are talking about...i know they make accessory belts and timing belts as well for alot of different cars....and from what i understand, gates makes alot of the belts for the dealers as well
Old Dec 16, 2006 | 01:43 AM
Pondus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA_B18C1 &raquo;</TD></TR><TR><TD CLASS="quote">i seriously wouldn't spen 200 on a aftermarket timing belt..i rather use a brand new OEM belt..i brother inlaw has a greddy timing belt and just after 1000 miles that belt looked like SH*T with color all faded and junk</TD></TR></TABLE>
I'd rather spend some extra $ on a belt than have my Toda C's eat up a OEM belt and then have to rebuild the motor, with ported head and all.
Old Dec 16, 2006 | 07:26 AM
Natural Aspirations's Avatar
Where can these belts be found?
Old Dec 16, 2006 | 10:10 AM
d16dcoe45's Avatar
Default Re: (Natural Aspirations)
robear racing lists them. GSR part number is: GAT-t247rb and its $106, b16/b17 part number is: GAT-227rb and its $99--still pretty cheap--its only the d16a6 belt that is $84.
Old Dec 17, 2006 | 09:33 PM
soulpwr's Avatar
Considering that Gates makes factory belts you'll probably be ok with it. Toda belts have been known to snap. I'd much rather use a gates belt.
Old Dec 18, 2006 | 05:34 AM
d16dcoe45's Avatar
Default Re: (soulpwr)
I have heard about every kind of belt breaking. Are you sure that Toda belts can break with more prevalence than an oem belt?
Old Dec 18, 2006 | 04:08 PM
NA_B18C1's Avatar
i think every belt lasts just as long as you maintain and check on them once in a while
Old Dec 18, 2006 | 04:27 PM
Forrest Gump 9's Avatar
OEM FTW!!
kndaqikEG
Mar 27, 2005 09:42 AM
turbociv
12
May 1, 2004 06:43 AM
Richard.
16
Jan 19, 2004 10:20 PM
allmotorhatch
Jun 8, 2003 05:57 AM
Eric R
Aug 3, 2002 02:44 AM
