wheel bearing Q?
Old Dec 14, 2006 | 08:19 AM
90crxdriver's Avatar
Default wheel bearing Q?
My drivers side hub bearing is wobbling and needs to be replaced. Is it possible to put the hub off my 89si crx on my 90si crx. I looked at them both and they look the same. I don't have a ride to get the bearing pressed out or in and no $$$ to buy the new bearing. The 89si crx has almost brand new wheels bearings and the cars going to be scraped anyway.
Sorry the Q was will the 89si crx wheel hub fit a 90si crx. (Bolt on, no moding)
thanks
Old Dec 14, 2006 | 08:24 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: wheel bearing Q? (90crxdriver)
It should, might want to check the part #s just to be sure.
Old Dec 14, 2006 | 08:55 AM
Default Re: wheel bearing Q? (wiZCo)
ok thanks I took it off the 89 and it looks identical.
I"ll check the parts #s whare can I find said #s?
thanks
Old Dec 14, 2006 | 09:09 AM
Creator's Avatar
just call your local dealership and have them check for you
Old Dec 14, 2006 | 09:10 AM
Default Re: wheel bearing Q? (Creator)
ok thanks for the help.
Old Dec 14, 2006 | 10:03 AM
dr_latino999's Avatar
Those hubs are the same, so are the wheel bearings.
Old Dec 14, 2006 | 02:44 PM
Default Re: wheel bearing Q? (dr_latino999)
Its back together and working great thanks for the help.
I had a small problem with the ball joint for the steering but took the one off the 89 and it worked.
thanks for all the help and thanks for the quick replys
03K20A3Si
Classic Hondas
Aug 12, 2011 02:31 PM
anotherstar_noz
Apr 8, 2008 11:56 AM
crx_kid
Jul 25, 2004 12:13 AM
Elkins911
Jun 15, 2003 02:29 AM
olddriver
Mar 16, 2002 05:17 PM
