whats the difference between saturated vs peak and hold injectors
Old Dec 14, 2006 | 07:08 AM
rohec04's Avatar
Default whats the difference between saturated vs peak and hold injectors
need help asap
Old Dec 14, 2006 | 07:13 AM
Televator's Avatar
Default Re: whats the difference between saturated vs peak and hold injectors (rohec04)
https://honda-tech.com/zerothread?id=579490
Old Dec 14, 2006 | 07:42 AM
crxking1's Avatar
IMPORTANT INFORMATION - PLEASE READ
All Acura/Honda's before 1992 use Peak & Hold style injectors. These are low resistance injectors that are measured at 2.5/3 ohms(measured at 43 P.S.I.G).
Acura/Honda's from 1992 and newer(with the exception of 92-96 Preludes) use Saturated injectors. These are high resistance injectors that are measured approx. at 12-16 ohms (measured at 43 P.S.I.G).
All Acura/Honda's that are 1996 and newer require the use of injector clips. Be sure to add them to your order if you fall in this category.
This info was taken from http://www.inlinefour.com
Old Dec 14, 2006 | 01:57 PM
rohec04's Avatar
Default Re: whats the difference between saturated vs peak and hold injectors (AntiguaCrx)
thanks for the help
Old Jan 22, 2007 | 06:36 PM
99TurboBlue's Avatar
I'm a Jackass cause i dont like to follow the rules.
now if i already have rc 310's in my 99 si, i assume that there are already clips in the car that i need so when i buy 550's or 750's i can just swap em right out?
ma_rio44
Nov 10, 2007 02:22 AM
grnhatch94
Feb 1, 2006 05:48 PM
hondaeg8
Oct 1, 2005 02:18 PM
TurboJesse
Jun 13, 2004 05:00 PM
