1992 Accord Hood latch
Old Dec 13, 2006 | 10:52 PM
voodooutt's Avatar
Default 1992 Accord Hood latch
I have a '92 Accord, the hood latch won't work. The secondary latch grabs, but when I try and close the hood, it won't latch. I've probed around a bit to see why it might not latch properly, but no luck. I don't want to go ripping apart the whole assembly - wondering if this might be a common problem with a common fix?
thanks.
Old Dec 15, 2006 | 08:41 AM
hondadude's Avatar
Default Re: 1992 Accord Hood latch (voodooutt)
try using a screwdriver on the latch to see if it will in fact lock in place when pushed down. There are 3 10mm bolts that allow the latch to be adjusted. It could be the cable is hung up and not isn't releasing the latch assy.[holding it in the 'unlatch' position] You'll have to really look for yourself to figure out this problem.
honda2112
Jul 11, 2013 08:19 PM
j4s0n1337
Jun 13, 2011 01:59 PM
pnyklr
Apr 12, 2011 11:31 AM
Integra_drk
Apr 12, 2007 04:42 PM
iLUVmyACCORD
Dec 25, 2004 02:45 PM
