F20b swap
i think its a pretty lengthy answear that noone is going to be able to provide u with....do a search on the subject and take up bits and pieces thats the best you can do anyways....you'll never get all the answears out of one post
Run a wire for VTEC, OBD1>OBD2 conversion or vice versa, prelude (92-96) driver's side engine mount. If your not already a 5spd, do that. Some sort of ECU or engine management
When I was thinkin about doing this swap around here I was told it's jus like doin an H22 swap... jus I couldnt find the ecu it needed... I was told a p13 will work but it's still not the best you can do... I jus dunno what ecu is used onna f20b... good luck
