JDM ITR (B18c) vs USDM ITR (B18c5)
Old Dec 13, 2006 | 08:48 PM
goldegg's Avatar
Default JDM ITR (B18c) vs USDM ITR (B18c5)
Im planning on swapping the b16 out of my eg hatch in the spring,
right now it comes down to either a usdm b18c5 or a jdm b18c itr, as i dont have the time or money at the moment to play around with a K which was my origional plan.
the reason im not building the b16 is because im looking for a drop in swap, i/h/e and tune and leave it pretty much other than bolt ons (reliability is key)
around here its usually about 900-1000 more for a JDM ITR vs the USDM and basically what ide like to know is if its worth it for the extra .5 compression point.
Ive done some pretty extensive searching, but I still havent found an answer from people who have delt with both engines.
Old Dec 14, 2006 | 12:50 AM
92TypeR's Avatar
FSAE
Default Re: JDM ITR (goldegg)
If you are just swapping the longblock, base your decision on price.
Old Dec 14, 2006 | 07:28 PM
Del Soouulll's Avatar
Default Re: JDM ITR (92TypeR)
B20Vtec ITR style Pistons, and use ur B16 head
Old Dec 14, 2006 | 08:54 PM
Runnerdown's Avatar
Default Re: JDM ITR (bLack*)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bLack* &raquo;</TD></TR><TR><TD CLASS="quote">B20Vtec ITR style Pistons, and use ur B16 head </TD></TR></TABLE>
word up, itr motors are way overpriced for what you get. you can put together a new, never been beat on b20 vtec and make far more tq and hp for less money.
Old Dec 15, 2006 | 07:27 AM
mar778c's Avatar
Community Builder
Community Influencer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote">
word up, itr motors are way overpriced for what you get. you can put together a new, never been beat on b20 vtec and make far more tq and hp for less money. </TD></TR></TABLE>
X2 agreed
Old Dec 15, 2006 | 10:05 AM
kangaroo's Avatar
Default Re: JDM ITR (Runnerdown)
but then you have to worry about if your doing the build right and if you don't know how to do it yourself then labor is going to kill.
Plus you don't get the ITR tranny.
Old Dec 15, 2006 | 11:52 AM
itralex's Avatar
I agree
we at Dou Lik can set you up with a awesome setup for a good price
Old Dec 15, 2006 | 10:57 PM
goldegg's Avatar
Default Re: JDM ITR (itralex)
I would really rather not build the motor since ive had bad luck with built engines in the past that were daily driven.
I know its more than possible to get a good builder than can build one, but ide rather not right now.
any concenus on the jdm itr (98+) vs usdm itr?
Old Dec 16, 2006 | 12:23 AM
itralex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goldegg &raquo;</TD></TR><TR><TD CLASS="quote">I would really rather not build the motor since ive had bad luck with built engines in the past that were daily driven.
any concenus on the jdm itr (98+) vs usdm itr?</TD></TR></TABLE>
well if you're not going to build it and pretty dead set on getting a ITR motor, I suggest that you get the JDM ITR motor as it has higher compression and we can easily get 94 octane here
Old Dec 16, 2006 | 08:07 AM
kangaroo's Avatar
GEt the 98+ jdm ITR motors.....they come with a better final dirve. 4.77!!
Old Dec 16, 2006 | 01:56 PM
Teamdiesel's Avatar
What makes you think 4.7 is better. When drag racing, I come from behind and pass 98' ITR's with my 96' ITR. Both of us were bone stock.
Old Dec 18, 2006 | 10:45 AM
goldegg's Avatar
Default Re: (Teamdiesel)
Does anyone run the JDM ITR motor on 91 octane?
or is 94 a must?
Old Dec 18, 2006 | 12:40 PM
ek9800's Avatar
Default Re: (goldegg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goldegg &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone run the JDM ITR motor on 91 octane?
or is 94 a must?</TD></TR></TABLE>
i ran a 12:9 compression car on 91
Old Dec 18, 2006 | 12:54 PM
XLR8 GS-R's Avatar
Default Re: (ek9800)
If your gonna go for the ITR swap do it right and go for the Japan motor/trans. You are gettting the ITR trans too, right?
Old Dec 18, 2006 | 02:43 PM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teamdiesel &raquo;</TD></TR><TR><TD CLASS="quote">What makes you think 4.7 is better. When drag racing, I come from behind and pass 98' ITR's with my 96' ITR. Both of us were bone stock.
Who said its going to be used for drag racing? Final Drives are a bit more for its attributes other than just drag racing.
Old Dec 18, 2006 | 03:35 PM
kangaroo's Avatar
sometimes....Mine varys from 92 octane to 93 octane..
no more no less.
jdm b18c-R
Old Dec 18, 2006 | 03:39 PM
realis9's Avatar
can you explain more? rather than FD could it just be your car was faster that his.
Old Dec 18, 2006 | 03:40 PM
realis9's Avatar
Default Re: (realis9)
is the gsr 4 and 5 in the JDM 98+ tranny that bad.
EF_typeR
11
Nov 11, 2010 06:09 PM
wtfmike
Feb 2, 2009 08:51 AM
noxlovexhere
May 4, 2005 04:15 PM
gulftiresinc
13
Sep 5, 2004 02:59 PM
