need help quick TPS remove pics
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zach_06 »</TD></TR><TR><TD CLASS="quote">take a dremel.. and cut a slash in the screw and then take a flat head and backthe screw out.... make sure u take the Throttle body off first... good luck</TD></TR></TABLE>
didnt work bump for help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboi86 »</TD></TR><TR><TD CLASS="quote">didnt work bump for help
You need to grind the head down first, almost flush with the plastic, then cut your notch.
</TD></TR></TABLE>You need to grind the head down first, almost flush with the plastic, then cut your notch.
you could take your dremmel all over again, and shave the whole head off.
I asked this same question a couple months go, the 'cutting a slash' worked with me.
