///////////F20b block w/ H22a head? Will this work, or be usefull in turbo set-up?\\\\\\\\\\\\
From what I found on search, the F20b blocks dont have the same reinforced cylinder walls as the H22's. Reason being, I was thinking the block would be able to hold greater PSI with a turbo.
With that said:
- Would a F20b block fit with a H22a head?
- As well as a H22 LSD tranny?
Also found in research, some mentioned boring out the block and putting in RSX pistons. Would they be worth it or should one go with an aftermarket piston set?
With all that said, my plans were to have a boosted motor (f20b block, h22a head, h22a lsd tranny).
Any info is appreciated!
2.2 teg
Jul 3, 2009 11:36 PM
2.2 teg
Nov 24, 2007 06:50 PM
2.2 teg
Dec 17, 2006 06:47 AM
