///////////F20b block w/ H22a head? Will this work, or be usefull in turbo set-up?\\\\\\\\\\\\
Old Dec 13, 2006 | 04:26 PM
2.2 teg's Avatar
Default ///////////F20b block w/ H22a head? Will this work, or be usefull in turbo set-up?\\\\\\\\\\\\
From what I found on search, the F20b blocks dont have the same reinforced cylinder walls as the H22's. Reason being, I was thinking the block would be able to hold greater PSI with a turbo.
With that said:
- Would a F20b block fit with a H22a head?
- As well as a H22 LSD tranny?
Also found in research, some mentioned boring out the block and putting in RSX pistons. Would they be worth it or should one go with an aftermarket piston set?
With all that said, my plans were to have a boosted motor (f20b block, h22a head, h22a lsd tranny).
Any info is appreciated!
Old Dec 13, 2006 | 04:48 PM
2fast4u831's Avatar
I'm really 2slow
Default Re: ///////////F20b block w/ H22a head? Will this work, or be usefull in turbo set-up?\\\\\\\\\\\\ (
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duce_Duce Teg &raquo;</TD></TR><TR><TD CLASS="quote">
With that said:
- Would a F20b block fit with a H22a head? Yes with some mods
- As well as a H22 LSD tranny? Yes
Also found in research, some mentioned boring out the block and putting in RSX pistons. Would they be worth it or should one go with an aftermarket piston set?Im not sure on this
Any info is appreciated!</TD></TR></TABLE>
Old Dec 13, 2006 | 04:53 PM
2.2 teg's Avatar
what "mods" have to be done to fit the block and head?
Old Dec 13, 2006 | 04:57 PM
The_Head's Avatar
I thought the F20B used an H22A head.
Old Dec 13, 2006 | 05:17 PM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Head &raquo;</TD></TR><TR><TD CLASS="quote">I thought the F20B used an H22A head.</TD></TR></TABLE>
yup
OP: why post this in two forums? ugh
Old Dec 13, 2006 | 06:01 PM
2fast4u831's Avatar
I'm really 2slow
some f20b are dohc without vtec I know you need to block off some oil ports on other F-series blocks.
Old Dec 13, 2006 | 06:06 PM
2fast4u831's Avatar
I'm really 2slow
double post
Old Dec 13, 2006 | 07:02 PM
2.2 teg's Avatar
Old Dec 13, 2006 | 07:04 PM
2.2 teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2FAST4U831 &raquo;</TD></TR><TR><TD CLASS="quote">double post </TD></TR></TABLE>
its to make sure i will get my question answered
Old Dec 13, 2006 | 07:26 PM
2fast4u831's Avatar
I'm really 2slow
scroll about 1/2 way down. shows pics not sure if its the same for all f-series or not.. might only be on f23
https://honda-tech.com/zerothread?id=1069869&page=2
another good one
https://honda-tech.com/zero...age=1
Modified by 2FAST4U831 at 8:42 PM 12/13/2006
Modified by 2FAST4U831 at 8:43 PM 12/13/2006
Old Dec 15, 2006 | 02:30 PM
prelittlelude's Avatar
im not sure if your f20b block has all the same oil drains as the h22 block, uf it doesn't you need to block off 2 of the oil drains in the head. all my pics are down in my thread that was posted above, dns is all screwy
Old Dec 17, 2006 | 06:47 AM
high_revs's Avatar
heads are the same...exactly the same if they are h22 heads...the non vtec ones i believe came with the 2 missing drains on the timing side.
h22sedan
Dec 17, 2006 08:34 PM
gulf imports
Jul 14, 2003 01:22 PM
