is there any sense in using titanium rods instead of still ones?
Old Dec 13, 2006 | 03:05 PM
xQB21x's Avatar
Default is there any sense in using titanium rods instead of still ones?
on n/a b20vtec?
Old Dec 13, 2006 | 03:37 PM
NA_B18C1's Avatar
i don't think it matters much..probably just a little weight difference and they cost around 400-1000 bucks a rod. good thing i didin't get it
Old Dec 13, 2006 | 03:50 PM
bawah's Avatar
Default Re: is there any sense in using titanium rods instead of still ones? (xQB21x)
the titanium rods r stronger
Old Dec 13, 2006 | 04:04 PM
xQB21x's Avatar
Default Re: is there any sense in using titanium rods instead of still ones? (crxrider)
may be they are stronger (but i'm doubtful about that) but good stilll rods are strong enough to handle everything. the weigh difference between eagle titanum rod (335 gr) and corillo still rods (421 gr) is less than 100 grams, would it affect much the engine's characteristics?
Old Dec 15, 2006 | 06:24 AM
NA_B18C1's Avatar
i didn't notice that there are companies out there that makes really light weight pistons to go along with the TI rods....i wonder how that would turn out like...using the light aftermarket crankshafts and etc...for the internals
Old Dec 15, 2006 | 08:49 AM
d16dcoe45's Avatar
Default Re: (NA_B18C1)
I highly doubt they are stronger--they are a bunch lighter though with proably equal or almost the strength of a forged steel rod.
Old Dec 15, 2006 | 06:42 PM
alterdcreations's Avatar
Default Re: (d16dcoe45)
their alot stronger
Old Dec 15, 2006 | 06:43 PM
Default Re: (alterdcreations)
even in their light weight their stronger
Old Dec 15, 2006 | 07:10 PM
xDicktonesx's Avatar
the **** is a still rod?
Old Dec 15, 2006 | 07:19 PM
600 c dans rule's Avatar
B A N N E D
Default Re: (xDEFTONESx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xDEFTONESx &raquo;</TD></TR><TR><TD CLASS="quote">the **** is a still rod? </TD></TR></TABLE>
I thought he ment that they didn't move.
Old Dec 15, 2006 | 09:31 PM
Combustion Contraption's Avatar
still = STEEL
Ti rods are not that much stronger than a good forged steel rod. If durabilty is even a thought, pass on the Ti rods.
Old Dec 15, 2006 | 10:17 PM
d16vtecx's Avatar
Default Re: (600 c dans rule)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 600 c dans rule &raquo;</TD></TR><TR><TD CLASS="quote"> I thought he ment that they didn't move.</TD></TR></TABLE>
lmao
Old Dec 15, 2006 | 11:24 PM
Kidnkorner's Avatar
Titanium has the same strength as Steel, but offers it in a lighter package. Chromoly is stronger than steel, and lighter at the same time. The only benefit that titanium would offer over a steel rod is weight savings. Chromoly rods ftw. I have read about composite material used to make rods, possibly even kevlar which I believe is either 3 or 6 times stronger than steel and discoverd by accident.
Old Dec 16, 2006 | 08:50 AM
Default Re: (Lynx Bus Type R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lynx Bus Type R &raquo;</TD></TR><TR><TD CLASS="quote">Titanium has the same strength as Steel, but offers it in a lighter package. Chromoly is stronger than steel, and lighter at the same time. The only benefit that titanium would offer over a steel rod is weight savings. Chromoly rods ftw. I have read about composite material used to make rods, possibly even kevlar which I believe is either 3 or 6 times stronger than steel and discoverd by accident. </TD></TR></TABLE>
no. an equal piece of titanium next to an equal piece of 1020 tensile steel has no comparison. maybe what youre trying to say is, since titanium is so much lighter you can use a lot more material, possibly end up a little lighter with the same strength.
like this
l vs l weighting the same because the thick ti one is lighter, however niether will be stronger.
that is why titanium shoudlnt be used for anything where tensile strength is a factor.
look at how many road race bicycle frames you see made out of ti. now find a ti bmx frame made for someone older than 7.
ever seen the carbon kevlar valves?
Old Dec 16, 2006 | 09:24 AM
d16dcoe45's Avatar
Exactly what xDEFTONESx said, titanium is not stronger than steel--I know steel is hell of alot stiffer. Its just that titanium is a good bit lighter so more can be used while still being lighter than a steel rod. I think iron/steel is around 7.5 grams/cc, titanium is 4.5 grams/cc and I am positive aluminum is 2.7 grams/cc. When I used to race mountain bikes years ago, it was always regarded that titanium frames were some of the flexiest but had good shock absorbtion qualiities--aluminum frames (when using large tubing) were very stiff and gave a stiff ride, and a good steel frame was usually a bit heavier than both but gave a very good ride.
thats correct.
reference to deftones
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alterdcreations &raquo;</TD></TR><TR><TD CLASS="quote">their alot stronger</TD></TR></TABLE>
if you take a ultra light forged steel h22 rod 485grams or so
and you compare it to a titanium h22 rod that weighs 485 grams , that titanium rod will be alot beefier and where as the ultra light rod is goo only for all motor the titanium rod could be used for boost
Old Dec 16, 2006 | 11:05 AM
Phil M's Avatar
Ti is stronger than steel. BUT, Ti dosen't bend or flex, it breaks. Steel flexes and stretches. You don't want a part that dosen't have a little give in a daily driver.
Example. If ti was lighter, stronger or as strong as steel why woulnd't they use them for roll cages in professional cars? Because it dosen't bent or stretch, it breaks..
Old Dec 16, 2006 | 11:10 AM
Default Re: is there any sense in using titanium rods instead of still ones? (theyoungone)
high tensil strenth
Old Dec 16, 2006 | 11:28 AM
dont they come as oem in the nsx
some of those guys make good boosted hp on them
Old Dec 16, 2006 | 11:50 AM
Aquafina's Avatar
Default Re: is there any sense in using titanium rods instead of still ones? (alterdcreations)
Less tensile stress in boosted engines.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Don Lackey in an old OP ti rod thread &raquo;</TD></TR><TR><TD CLASS="quote">Ligthening the reciprocating wieght by 200 - 300 grams per cylinder in Honda engines have netted 15whp+ at 9.5k rpms and above.</TD></TR></TABLE>
Modified by Aquafina at 4:14 PM 12/16/2006
Old Dec 16, 2006 | 12:33 PM
Default Re: is there any sense in using titanium rods instead of still ones? (Aquafina)
all thing considering this is the all motor forum and the Acura NSX is n/a from the factory. those rods a known for its strenth
Old Dec 16, 2006 | 04:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alterdcreations &raquo;</TD></TR><TR><TD CLASS="quote">all thing considering this is the all motor forum and the Acura NSX is n/a from the factory. those rods a known for its strenth</TD></TR></TABLE>
You sure about that? You sure the NSX con rods are 100% ti?
Old Dec 16, 2006 | 07:54 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by theyoungone &raquo;</TD></TR><TR><TD CLASS="quote">Ti is stronger than steel. BUT, Ti dosen't bend or flex, it breaks. Steel flexes and stretches. You don't want a part that dosen't have a little give in a daily driver.
Example. If ti was lighter, stronger or as strong as steel why woulnd't they use them for roll cages in professional cars? Because it dosen't bent or stretch, it breaks..</TD></TR></TABLE>
no no no no no, titanium is as soft as warm butter. it bends. it flexes. more so than steel . which is why the race teams that use them are coutning passes until they need to change them out.
pull up the melting point of ti and youll see how low it is as well.
Old Dec 16, 2006 | 09:00 PM
Phil M's Avatar
Default Re: is there any sense in using titanium rods instead of still ones? (xDEFTONESx)
Wrong.
Titanium is as strong as steel, but 45% lighter. It is 60% heavier than aluminum, but twice as strong
Ti
Melting Point:1660oCBoiling Point:3287oC
Atomic Weight:47.90
Steel melts at about 1300 C
It's boiling point is about 3000 C
Old Dec 16, 2006 | 09:03 PM
Phil M's Avatar
I have a metallurgy book in my hands now....
