1987 Accord DX (CARB) Won't Start!
Old Dec 13, 2006 | 02:18 PM
Dhippie's Avatar
Default 1987 Accord DX (CARB) Won't Start!
I have a 1987 Honda Accord Dx. I got it a few weeks ago and its pushing 300,000 miles. It ran strong up untill a few days ago. It overheated , but there was no coolant so i filled her up and she didn't overheat anymore. Farther on down the road is when it lost power on the highway. It DID NOT stall, but lost all its "Umf". We had to pull off the highway because it went from about 65mph to less the 40mph. It wouldn't start so we towed it to the house. After a battery Charge it ran okay for about a day or so. I was Still worried about it so i woke up and went out to start it. It fired right up, i turned it around and moved it into the garage. It hasn't started since. I've checked about everything, Plugs get spark, Carb has got gas flow, Tried Spraying Started Fluid and it still won't start. I took off the Oil Fill cap and the Valves and Arms move when it cranks. It sputtered for a few seconds and died 1 or 2 times after i moved it into the garage, but i haven't got it running since. When I pull one plug and hold it to the block, the plug sparks and the engine almost starts but doesn't catch, unlike it does when all plugs are in. When everything is on correctly and in place, it just cranks at one steady pace with out speeding up or anything. Please help me out i've been trying to fix it for days and i can't figure it out.
Old Dec 13, 2006 | 02:27 PM
jimjonez
Guest
Posts: n/a
Default Re: 1987 Accord DX (CARB) Won't Start! (Dhippie)
did you check the distributer cap and rotor???
Old Dec 13, 2006 | 02:43 PM
88LXi68's Avatar
The car has 2 fuel filters, I would change those and also check cap and rotor.
What color is the spark?
Also, check out http://www.3geez.com it is an 86-89 Accord Messageboard and may be more helpful.
Old Dec 14, 2006 | 10:53 AM
Dhippie's Avatar
Default Re: (88LXi68)
I Checked The Cap and Rotor and everything looks clean a functional. The Spark is Bright white with a hint of blue, not as blue as i'd like. I'll go see how much some filters will run me at the parts store
Dec 15, 2016 11:57 AM
Debra78
Nov 7, 2013 01:27 PM
dhoff024
Sep 3, 2009 02:01 PM
thisbravenew_world
May 24, 2008 02:52 AM
hondalaughoutloud
Aug 18, 2005 07:00 PM
