How to get to the fuel pump in a 4th gen?
Old Dec 13, 2006 | 01:47 PM
preludedriva's Avatar
Default How to get to the fuel pump in a 4th gen?
If it directly under the backseat? if so how do i remove the backseats?
Old Dec 13, 2006 | 01:49 PM
BB2H22's Avatar
10mm bolts and there are two plastic clips per seat at the bottom. Just lift up the cushion a little it and you will see them.
Old Dec 13, 2006 | 02:42 PM
ninja 6's Avatar
Default Re: (BB2H22)
Once you get there, it has a shiny cover on it thats held down by phillips screws IIRC. Not exactly under the backseat, but more along the center underneath the center console.
Old Dec 13, 2006 | 09:52 PM
cool thanks
Old Dec 14, 2006 | 04:40 AM
fasterthanueg's Avatar
Default Re: How to get to the fuel pump in a 4th gen? (preludedriva)
but what side is it on ( 2-peice seat) ?
Old Dec 14, 2006 | 05:01 AM
WhiteBB2's Avatar
is there a write up on changin the fuel pump anywhere?
Old Dec 14, 2006 | 06:20 AM
nonvteclude's Avatar
Default Re: How to get to the fuel pump in a 4th gen? (fasterthanueg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fasterthanueg &raquo;</TD></TR><TR><TD CLASS="quote">but what side is it on ( 2-peice seat) ?</TD></TR></TABLE>
its in the middle, and the fuel pump is the one closest to the drivers side
Old Dec 14, 2006 | 07:48 AM
CGags13's Avatar
you gotta rip out the back seats and that little cross-brace for the most room to work...have fun twisting/rotating/pushing/pulling the pump out....dont get too high with that pump out
Old Dec 14, 2006 | 08:21 AM
championshipwhite93si's Avatar
Default Re: (CGags13)
its not hard.. but its not a civic either...
Old Dec 15, 2006 | 02:31 AM
k me and my buddy just got done swappin out the F22 fuel pump for his walboro 255 fuel pump that was made for a civic
taking out the back seats wasnt too hard took about 20 minutes mosst of it popped off bout 8 bolts total minus the ones on the pump itself
we had to swap pieces from the new pump to the old, swapping socks and sensor plugs from each pump
we had fitment problems due to the sock not going into the slot correctly )the civic and prelude socks are aimed in differnet directions) we had to do some adjustments finally got it in
it works great and it sounds great too the high pitch noise it makes hahaha
to take apart the interior replace and fit the pumps and replace interior it took around 2 hours to do
SilverPanda
Oct 3, 2007 01:56 PM
AtxFourFive
Jan 7, 2007 10:02 PM
delguiner
Sep 7, 2006 09:31 AM
jdm206
May 14, 2006 05:33 AM
wumba
Apr 7, 2005 10:08 PM
