B16 intake manifold set up...a little different from the norm...
Old Dec 13, 2006 | 01:35 PM
20lbbooster's Avatar
Default B16 intake manifold set up...a little different from the norm...
Some of you have seen the pics and videos that I have posted of the "b16 build" that we did on a white CRX a few months back. Until earlier this week, we had been running TWM ITBs on the car and the car ran great. the power was right at 240, and the car had run a best time of 11.56 @ 118mph.
Well, in a quest to run our own fabricated parts on the car, and get back into an intake manifold instead of ITBs, Huy decided to fabricate his own intake manifold. At first glance, it is a funny looking intake manifold, but after dyno'ing the car with the new mani, the results are pretty impressive. We weren't really expecting to see much gain on the dyno really, just trying to get close to the ITBs power. We expect that the new manifold/intake design would yield good results on the track due to air being stuffed into the intake. We were very happy with the dyno results and look forward to hitting the track this weekend.
Take a look. I'm sure some will hate it, and others will appreciate the fab. Feedback welcome....
Old Dec 13, 2006 | 01:48 PM
DarkBB4's Avatar
Default Re: B16 intake manifold set up...a little different from the norm... (20lbbooster)
looks GREAT!
the welds are amazing!
Old Dec 13, 2006 | 01:57 PM
9bells's Avatar
OG Fabricator
Very nice work. Impressive results.
Second time Ihave seen an intake outdo TWM's.
Old Dec 13, 2006 | 02:01 PM
mwieczorek43's Avatar
Default Re: B16 intake manifold set up...a little different from the norm... (9bells)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkBB4 &raquo;</TD></TR><TR><TD CLASS="quote">the welds are amazing!</TD></TR></TABLE>
you can say that again
Old Dec 13, 2006 | 02:17 PM
RC000E's Avatar
Default Re: B16 intake manifold set up...a little different from the norm... (mwieczorek43)
Why the decision to put the throttle body a mile away from the intake valves? Talk about delayed throttle response versus ITB's. Nice work though otherwise IMO.
Old Dec 13, 2006 | 02:25 PM
Default Re: B16 intake manifold set up...a little different from the norm... (RC000E)
Actually, the throtle response is great and the car revs very fast. We put it away from the plenum in order to get a more laminar air flow into the plenum/runners. So far it is good stuff...the real test will be on the track.
Thanks for the props.....
Old Dec 13, 2006 | 02:31 PM
EKhatch's Avatar
Good stuff man. Do you have the video hosted anywhere else? I see that it has been taken down on the site you linked to in a previous thread.
Old Dec 13, 2006 | 02:37 PM
ebydrc's Avatar
Banned
Default Re: B16 intake manifold set up...a little different from the norm... (EKhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 20lbbooster &raquo;</TD></TR><TR><TD CLASS="quote">Actually, the throtle response is great and the car revs very fast. We put it away from the plenum in order to get a more laminar air flow into the plenum/runners. So far it is good stuff...the real test will be on the track.
Thanks for the props.....</TD></TR></TABLE>
ive seen this done a few although never that far away, its suppose to help to an extent. meaning there is a happy medien between to far and really close, throttle body diemeter is also a factor in throttle response.
looks great
david
Old Dec 13, 2006 | 03:30 PM
LSEGHATCH's Avatar
Default Re: B16 intake manifold set up...a little different from the norm... (ebydrc)
Different, exactly what the industry needs. Too much of the same stuff going around right now.
Old Dec 13, 2006 | 04:14 PM
dualweberVW's Avatar
Default Re: B16 intake manifold set up...a little different from the norm... (LSEGHATCH)
nice results and awesome fab
why did you opt for a single throttle body design instead of that plenum design over the throttle bodies?
Old Dec 13, 2006 | 04:33 PM
Evile140's Avatar
The radius inlets inside the plenum...are they the ones from Ross?
Thanks
Randy
Old Dec 13, 2006 | 04:44 PM
Default Re: (Evile140)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evile140 &raquo;</TD></TR><TR><TD CLASS="quote">The radius inlets inside the plenum...are they the ones from Ross?
Thanks
Randy </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dualweberVW &raquo;</TD></TR><TR><TD CLASS="quote">nice results and awesome fab
why did you opt for a single throttle body design instead of that plenum design over the throttle bodies? </TD></TR></TABLE>
Since I am not the fabricator, I am going to let Huy answer your questions.
I know huy takes pride in fabricating his own parts and running them on his/customers cars. On this car he made the cross member/traction bars, header, intake manifold, motor mounts radiator support and some other random stuff. Its easy to buy parts and bolt them on, but it is much more of a challenge to make your own parts, build your own stuff and be fast too. We are hoping to see some low 11s this weekend! Again, thanks for the props.
Louie
Old Dec 13, 2006 | 04:49 PM
Default Re: (20lbbooster)
Here is a short video from the dyno last night and one from the IFO event in Dallas a few months back
RIGHT CLICK SAVE AS
http://www.inline-racing.com/l...o.mpg
http://www.inline-racing.com/louie/huy%20ifo.mpg
Modified by 20lbbooster at 2:22 AM 12/14/2006
Old Dec 13, 2006 | 05:24 PM
Lamchop0000's Avatar
nice i dig it
what are the specs on that motor if you dont mind sharing
Old Dec 13, 2006 | 05:55 PM
*Boostwerks*'s Avatar
Where was vtec engaged at? I'm hoping thats what the cause of the blip in the HP curve was.
It also seems weird to me how the torque is falling off so much after 7k...? Is that normal for built N/A motors? I'd expect a B16 to keep climbing...? Just curious is all.
The end results don't lie though...Great stuff!
Old Dec 13, 2006 | 06:04 PM
Default Re: (Boostwerks.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostwerks.com &raquo;</TD></TR><TR><TD CLASS="quote">Where was vtec engaged at? I'm hoping thats what the cause of the blip in the HP curve was.
The end results don't lie though...Great stuff! </TD></TR></TABLE>
No VTEC..(crane roller cam) and yeah, it is pretty typical of NA motors to drop off torque like that. Huy can tell you more about the dip in the graph there as he is the tuner. He hasn't even seen this thread yet because he is at the shop working!
Old Dec 13, 2006 | 06:07 PM
No VTEC..(crane roller cam) and yeah, it is pretty typical of NA motors to drop off torque like that. Huy can tell you more about the dip in the graph there as he is the tuner. He hasn't even seen this thread yet because he is at the shop working!</TD></TR></TABLE>
Right on. I wonder if it's a harmonic or tuning issue with the dip then. But great work guys!
Old Dec 13, 2006 | 06:25 PM
EKhatch's Avatar
Thanks for posting up the vids.
What gear did you dyno the car in?
Old Dec 13, 2006 | 06:36 PM
I B BANGGIN's Avatar
Default Re: (EKhatch)
.....looks good!
wonder how it would work on a turbo motor..
Old Dec 13, 2006 | 07:12 PM
Default Re: (I B BANGGIN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKhatch &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for posting up the vids.
pulls made in 3rd gear
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I B BANGGIN &raquo;</TD></TR><TR><TD CLASS="quote">.....looks good!
wonder how it would work on a turbo motor..</TD></TR></TABLE>
you know...we were wondering the same thing. We will probably try it out on the next big power turbo car we build.
first things first, low 11s...
Old Dec 13, 2006 | 07:32 PM
well when you guys are ready to make another let me know.. ill be more than happy to buy it and let you guys know how it does....maybe i can try it on my race car..
Old Dec 13, 2006 | 07:37 PM
boosted94cx's Avatar
* B A N N E D *
why didn't he raise the inlets off the floor of the plenum? just ease of fabrication for now?
btw...looks great, like the inlet idea
Old Dec 13, 2006 | 08:13 PM
Professor15's Avatar
looks nice...how much does the rex weigh?
Old Dec 14, 2006 | 06:45 AM
kid-honda's Avatar
That a great idea and it seems to have worked so far on a dyno, I would have never thought of that throttle body location.
My only suggestion would to have rolled a large single piece of metal for the main body or done a better fit up to smooth the edges on the inside to improve flow but maybe you did? and that was a test fit pic?
Old Dec 14, 2006 | 06:51 AM
LurkerS8's Avatar
Looks even better in person. Can't wait to see it go down the track at IFO this weekend. Props to my boys at Inline Racing.
