traction bar question
i have a stock 89 si crx. the question i have is that if i buy a traction bar for D serie now, will i have to change to another traction bar if i swap to B series?
are B and D traction bars different?
The only difference is the front mount point B swaps don't use it, if you get some new stiffer mounts for your D motor then you don't need to run the front mount either...you can get one with the bracket and then just cut it off when you swap
Thanks for info guy, this way i dont have to worry when buying traction bar.
So...what traction bar is good?
Thinking Fullrace(but dont wanna spend on the radiator) or Jimfab(but they out of bussiness) so whats next in the list that you guys recommend? something like Fullrace but not require buying their radiator.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ESP-net »</TD></TR><TR><TD CLASS="quote">buy once drive off happy sold over 200 sets no complaints
http://www.explicitspeedperfor....html</TD></TR></TABLE>
very happy with mine
yellowrexsi
Mar 27, 2006 04:22 AM
