How do I test my Radiator fan & How do I connect a fan switch?
Old Dec 13, 2006 | 01:05 PM
Nameless Warrior's Avatar
Default How do I test my Radiator fan & How do I connect a fan switch?
My radiator fan is not working and I am having overheat problem in traffic. I read some of the threads regarding this, and they said to "jump" the fan to see if it's working. How exactly do you do that? Also, couple people recommend if the fan is working I should just wire it through a switch so I can have it on and off whenever I want. Any of you guy have a write up about this?
Old Dec 13, 2006 | 02:24 PM
Perfectionist's Avatar
Default Re: How do I test my Radiator fan & How do I connect a fan switch? (Nameless Warrior)
The fan connector has a power and ground to it. If you pull the connector for it and apply battery volts to the power side, it should run. The temp sensor for the fan completes the circuit to ground when the engine gets hot enough if it's working. You could just run a wire from the sensor, to a switch, and the other leg to ground to turn it on and off manually. But first, I would make sure the cooling system is working as designed. Thermostat ok, no air in coolant, no leaks, radiator ok, etc.
Old Dec 13, 2006 | 02:27 PM
Default Re: How do I test my Radiator fan & How do I connect a fan switch? (Perfectionist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Perfectionist &raquo;</TD></TR><TR><TD CLASS="quote">The fan connector has a power and ground to it. If you pull the connector for it and apply battery volts to the power side, it should run. The temp sensor for the fan completes the circuit to ground when the engine gets hot enough if it's working. You could just run a wire from the sensor, to a switch, and the other leg to ground to turn it on and off manually. But first, I would make sure the cooling system is working as designed. Thermostat ok, no air in coolant, no leaks, radiator ok, etc.</TD></TR></TABLE>
phew finally an answer!
yea, I know for sure th STAT is working. I am trying to see if it's the FAN or Thermostat switch. If it's the swtich i'll just replace that.
Where is the fan connector located at?
Old Dec 14, 2006 | 01:35 PM
The fan connector should be within a few inches of the fan itself. Shouldn't be hard to find. That is the point where you would power the fan directly from the battery to make sure it works. The actual location of thermo sensor for the fan is another story. Could be under the distributor or on the back of the block. I don't want to guess.
Old Dec 14, 2006 | 05:44 PM
sexyrex's Avatar
what kind of vehicle do you have? the fan switch is usually a 2 prong sensor coming out of the block, on mine its near the oil filter. pull the wires off, and jump the two wires with cotter pin or wire or something, and the fan should turn on with the key ON, if not check your fuse. if its your fuse, replace it, and jump wires again. if it blows than its your fan motor, replace it and retest.
Old Dec 14, 2006 | 06:44 PM
Default Re: How do I test my Radiator fan & How do I connect a fan switch? (sexyrex)
I fixed my problem.
It came out to be a bad Thermostat switch on the Thermostat housing. Bought a new one from Honda for 45 bucks.
A little piece of **** like THAT for 45 BUCKS!!!
maverick32
Jun 17, 2009 10:49 PM
Nameless Warrior
Dec 15, 2006 01:24 PM
jDMJeRk
May 4, 2005 07:43 PM
pub
Jun 10, 2003 09:47 AM
