approx how much does it cost for a machine shop to fit aftermarket rods?
Old Dec 13, 2006 | 12:53 PM
the.hamburglar's Avatar
Default approx how much does it cost for a machine shop to fit aftermarket rods?
i was wondering becuase when people are talking about bulding up the motor with rods and pistons and say rods are only an extra $300 you also have to remember that you need bearing and lots of machine work right? so what does it really cost to get the rods fit for the new bearings and/or the cranks journals machined? i could see this getting really expensive?
Old Dec 13, 2006 | 06:11 PM
NJIN BUILDR's Avatar
Default Re: approx how much does it cost for a machine shop to fit aftermarket rods? (the.hamburglar)
There are no extra costs above the cost of the rods.They take the same bearings as stock rods (although the size may vary slightly).
Old Dec 13, 2006 | 06:31 PM
Default Re: approx how much does it cost for a machine shop to fit aftermarket rods? (NJIN BUILDR)
yeah but there are certain clerences right? i mean you need to have so much tolerance between the bearing and the journal. i cant remember for a honda but its like 15/1000" right. and then you need to look at that chart for the colors of bearings and everything so im just wondering what it will all cost to build the bottom end?
Old Dec 13, 2006 | 07:04 PM
You still need to do that with stock rods.The cost people are talking about is the price difference between stock rods and aftermarket rods (usually Eagle rods).
Old Dec 13, 2006 | 08:19 PM
not it you leave the rods stock and just go with pistons and dont boost over 10 or something. so what would it all cost to get the aftermarket rods machined and bearings selected?
Old Dec 14, 2006 | 03:55 AM
OK I will say it again "there is NO additional machining to use aftermarket rods" except in a D engine which will need some block notching or if your using stock pitons.If your boosting than you should be using a low compression forged piston anyway.As far as bearings go plastigage is only a few dollars and a few minutes to check your clearance.Most people start with green bearings.
Old Dec 14, 2006 | 04:22 AM
oh ok, so if there is no machining, then you need to go through alot of bearings to select the ones the right size? so its just a matter of trial and error using plastigauge? what about using ACL bearings? do they go up in a size of 3/1000 like honda bearings? just wondering because the only reason i didnt get rods or pistons this year was all the extra time and money it was going to take to get all the machine work done. that said now im kind of changing my mind and maybe going to contact and new machine shop.
Scott53092
Apr 16, 2014 12:27 PM
GEN2 LS
Aug 21, 2009 01:44 PM
93H22ACX
Apr 27, 2004 09:05 AM
crx1856
Sep 20, 2003 01:15 AM
