axle qustion
Old May 11, 2002 | 05:45 PM
si foo's Avatar
Default axle qustion
hey guy I need a little help here. I'm swaping a B16 sir motor into my civic hb si, I have a B16a2 half shalf and I'll be using 95 teg axles is that posible? do I have to do anything to make it fit?
Old May 11, 2002 | 07:03 PM
hardware17's Avatar
Default Re: axle qustion (si foo)
everything ive read says you have to have the modified ZC Integra axles and with that intermediate shaft. Try to find the 90-93 Integra intermediate shaft and axles. Much easier to modify
Old May 11, 2002 | 08:03 PM
EP3_05's Avatar
Pretty sure you are going to need to use the 90-93 integra intermediate shaft and axles.
Old May 11, 2002 | 08:07 PM
87posCRX's Avatar
Default Re: axle qustion (91civic)
i woulda swore it was the 86-89 teg axles : the had the USDM version of the zc.
Old May 11, 2002 | 08:09 PM
EP3_05's Avatar
Default Re: axle qustion (87posCRX)
He is swapping a newer b16a into his car that is the only reason I am a little hesitant to say the 90-93 axles. I used 90-93 integra axles when I swapped in my 1st gen b16a.
Old May 11, 2002 | 09:08 PM
si foo's Avatar
not understanding guys. So prettty much I can't use the half shalf off a 99 si with 95 teg axles? I'm stuck with those, unless I go buy 90-93 half shalf and axles. Trying to save as much as I can.........
Old May 11, 2002 | 11:27 PM
Giuseppe's Avatar
if the half shaft u have is the same as a 95 teg half shaft then
youre fine with the parts u have good luck!!
Old May 12, 2002 | 02:10 AM
sparkz's Avatar
if you have the 99si half shaft then you can use 95 axles on both ends. although on my friends car, the driver side fit great but the passenger side seemed a little bit too long (still worked though) another of my friend has done the integ half shaft (99si, typer, gsr are the same) with 94+ integ driver side axles and 86-89 axles for the passenger side. seems to work great so far
Old May 12, 2002 | 01:00 PM
si foo's Avatar
Default Re: axle qustion (sparkz)
hey thanks guy I'll go give it a shot....
Old May 12, 2002 | 02:14 PM
JDMBOLONI's Avatar
i have a auto b16a1 and i know that the inermediate shafts are different from auto's and 5-spd (the angle is off) so i was wondering if i can get a 90-93 5-spd teg intermediate shaft for my swap? or can i still use my zc axles and 5-spd intermediate shaft from my zc on my b16?
lilhatch89
11
Oct 21, 2011 06:00 PM
Jays91DXhatch
11
May 10, 2005 07:11 PM
XANDER-666
Oct 7, 2002 12:04 PM
juicy.koreans.suck
10
Jan 10, 2002 10:47 AM
89sir-9
Nov 23, 2001 08:29 PM
