Spun bearing how long will it last?
Old Dec 13, 2006 | 09:10 AM
teamitr's Avatar
Default Spun bearing how long will it last?
If i just replace the bearing.
I know that is not the best thing to do but i need to drive the car for at least a month. so if i don't run it hard and try to keep it below 3000 rpm will it last me that long? from what i can see and feel the crank is smooth and the rod cap is not chewed up either. I know that some out of shape occured to either the crank or rod but what do you guys think?
Old Dec 13, 2006 | 09:14 AM
pizzamanprelude's Avatar
Default Re: Spun bearing how long will it last? (teamitr)
if were me i wouldn't drive it that long on a spun bearing, you might get through the month and finally crack the block open only to find the crank journal fukd, which bearing is it?
Old Dec 13, 2006 | 09:17 AM
teamitr's Avatar
Default Re: Spun bearing how long will it last? (pizzamanprelude)
its the rod bearing #2. and what i wanted to do is just replace it with a new one and drive it like that. until i hear the knocking again.
Old Dec 13, 2006 | 09:24 AM
Hawkze_2.3's Avatar
It might last, it might not...it's a gamble depending on how badly parts were damaged.
Old Dec 13, 2006 | 09:26 AM
teamitr's Avatar
Now would any of u guys know how to check what color bearing i need? i see the code on the rod/cap wich is 2 but i cannot see the letter on the side of the rod stem so how else can i figure out the color code?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamitr &raquo;</TD></TR><TR><TD CLASS="quote">its the rod bearing #2. and what i wanted to do is just replace it with a new one and drive it like that. until i hear the knocking again.</TD></TR></TABLE>
are you planning on opening it up anyway? if your you were going to replace one you might aswell replace all of them, it'll take you a weekend anyway
Old Dec 13, 2006 | 09:28 AM
i just re-read your post, i'm having a blonde moment, sorry! i know what you mean now
teamitr's Avatar
yeah I all ready got the pan out and everything so i'm going to relpalce all.
Old Dec 13, 2006 | 09:32 AM
thats about all you can do, pain in the ****. just remember to be careful when your applying torque to the rod bolts.
Old Dec 13, 2006 | 09:34 AM
teamitr's Avatar
yeah i will. so would you happen to know how tho get the code for the color bearing that i need?
Old Dec 13, 2006 | 10:32 AM
dont know mate, there are some real knowledgable people on here who know all about the insides off H22's, someone should be able to help. anyone have any idea?
Steady R
Aug 7, 2012 10:19 AM
soon2bdropped
Dec 14, 2010 03:42 PM
The Jacko
Feb 17, 2005 11:01 PM
hatchedzex
Oct 13, 2004 03:01 PM
hksbigboi4
Apr 16, 2004 07:48 AM
