h22 obd1 o2 sensor?
Old Dec 13, 2006 | 09:03 AM
buicklov's Avatar
Default h22 obd1 o2 sensor?
would an OBD1 h22 require a 4 wire 02 sensor. im am swaping one out in an ED. because i was thinking just buying a obd0 to obd1 conversion harness with a 4 wire o2 in it as well as a vtec subharness to hook everything up.. but im not sure if they have a 4 wire o2. or if they have 2 o2s and not just one
Old Dec 13, 2006 | 09:41 AM
Relic1's Avatar
the O2 sensor has to match the ECU not the engine.
so which ECU are you planning on running?
Old Dec 13, 2006 | 06:55 PM
buicklov's Avatar
Default Re: (Relic1)
p13
Old Dec 13, 2006 | 08:00 PM
charlee's Avatar
Default Re: (buicklov)
well, i have heard that people run p28's on the h22. wich in fact does require a 4 wire 02 sensor. quick question tho. is the p28 gonna run the car leaner since it was designed for a smallr motor that was not really a performance one relatively speaking. not trying to steal the thread tho.
Old Dec 14, 2006 | 09:00 AM
Relic1's Avatar
P28s can be used to run a H22 if they are chipped to run the H22. (converted P05/P06/P30 or a standard P72 will do it as well)
I know very little about the P13, but based on the bins I've seen, it looks like it uses a four wire O2.
**edit**
also... https://honda-tech.com/zerothread?id=650329
states you have to add the wires required for the one O2 sensor.
crxb16a90
May 6, 2016 11:19 AM
pleej
Oct 19, 2012 09:34 PM
BlownEJ6
Sep 18, 2003 06:42 PM
