brakes and maybe tranny????
i have this 90 crx and whenever i push on the brakes theres this sort of scratching sound and i have no idea what it is....does anybody know??? and no i dont need new brakes because they still have a lot of meat on them
also whenever i push in the clutch my car jerks usually to the left, i could just be drivin all fine not mashin then when i put in the clutch to shift it jerks hella....anybody know what that is??????
and last but not least when i slow down it seems like under 30 mph there is like this loud sorta grinding and rubbing noise coming from my axles and when i start movin it does it until a certain speed....any takers on that one???? thanks for all the help HT
last 2 problems sounds like it's your axle..jack up the car look under there for tears in the boots or axle grease everywhere..
1st sounds like brake pads scratching against the rotor..what kind of brake pads did you get? i know some organic and semi-metallic make scratching noise..that's why i try to get ceramic all the time..
