timing belt
Hello, i am building an LS for my ef. i am putting GSR oil and water pumps on it. does anyone know what timing belt i use if i used the GSR water pump? it is a 90 LS block with a 92 LS head and 93 GSR water pump. what timing belt do i use?
I would say use the LS belt. Your best bet would be to just purchase both the LS and GSR (which they both may fit) and take back the one that doesn't work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.speaker »</TD></TR><TR><TD CLASS="quote">you need the 94+ gsr timing belt when using the vtec 22 teeth waterpump.</TD></TR></TABLE>
Final Answer
Final Answer
turbo_b16_ex
Oct 4, 2005 11:06 AM
B18 CYA
May 11, 2005 03:11 PM
