Can you swap legend 2 piston calipers on a 93 ACCORD?
Old Dec 12, 2006 | 08:35 PM
JDM H22's Avatar
Default Can you swap legend 2 piston calipers on a 93 ACCORD?
I read about it being done on a 5th gen but what about the 4th. Can you swap parts to make the rotors not press on and make it the ones that are easy to take off? If some one could just write a parts list (pads, rotors, legend parts, etc) if they have done it before that would be great.
Old Dec 12, 2006 | 10:38 PM
SuShiBoiiii's Avatar
Default Re: Can you swap legend 2 piston calipers on a 93 ACCORD? (JDM H22)
pretty sure they can check the faqs up top
Old Dec 13, 2006 | 03:27 AM
TouringAccord's Avatar
H-T Order of Merit
like stated above, just check the FAQ's for your parts list. The 4th and 5th gen Accord have the same brake setup.
I know for sure one of the links for the rotor-over-hub conversion takes you to a thread on CB7Tuner which is a site for 4th gens.
As for the Legend brakes, same things needed for the 5th gen is needed for the 4th gen.
ok, here is that link I referred to on CB7.
Front Rotor-over-Hub Conversion
If you scroll down about 3/4 of the first page you'll see a long post by pwrusr, he has various lists of parts for various different setups. Just look at the one labelled Dual-piston brake upgrade with rotor-over-hub conversion, that'll tell you want you need exactly.
fw190bvi
Apr 20, 2005 01:56 PM
Stew Pidasso
Sep 19, 2004 03:22 PM
LDYKLLA
Apr 29, 2004 01:45 PM
G-MO
Jul 3, 2002 09:55 AM
TWG
May 23, 2002 11:16 AM
