removing rotor 94 accord
4 bolts holding the rotor to the hub, one nut holding in the axle, 3 nuts holding the knuckle to the car (upper/lower ball joints and tie rod), once you remove the knuckle so you can get the axle out, 4 more bolts holding the hub to the knuckle. Had to replace a bearing on one of those last weekend.
That things a bit#$. I tried...but couldn't free the hub. I was abe to get the bolts offf. There's a good tutorial someone has out. I had a quote from a local shop that qoted me about $50 to change the rotor (with the rotors provided). I might go that route.
dude! ive tried and failed. i looked at the tutorial and looks like i got to barrow my friends tools at his shop. ****! much longer time then i realized. ****!
you don't need to take the whole knuckle off the car, just remove the lower balljoint so you can swing the knuckle out and remove the axle from the hub, that'll give you the room to take the four bolts on the back out. Those four bolt are holding the bearing by the way.
Once those four bolts are removed, the hub/rotor/bearing assembly should come away from the knuckle. If not, some hammering should loosen it. If it's really bad like mine were though, you'll need to either take the car in for service or just remove the knuckles and take those to a machine shop and have the press everything apart and back together. Cost will probably be around 25 a side if you take the knuckles off and have a machine shop do the press work.
The job is just over complicated by Honda, but it's not impossible to do at home.
bryan0
Mar 25, 2014 10:57 PM
LOLO93PRELUDE
Jun 26, 2008 03:09 PM
