Speedometer help
Old Dec 12, 2006 | 06:33 PM
Gouki133's Avatar
Default Speedometer help
I'm having problems with my speedometer. I have a set of reverse glow overlays on them and all my gauges were working fine. One day my speedometer needle would get stuck at 20MPH and stay there no matter my speed. Sometimes it will kick back into place and work again and then when you least expect it will stop and drop to zero and raise to 20MPH and stay stuck once again..
Where can i check to see what might be causing this. As i said the gauges were working fine this just started happening.
thanks in advance.
Old Dec 12, 2006 | 07:01 PM
Gouki133's Avatar
Default Re: Speedometer help (Gouki133)
bump
Old Dec 13, 2006 | 07:55 AM
ryc555's Avatar
you might have a busted speed sensor bro!
http://i54.photobucket.com/alb...1.jpg
Old Dec 13, 2006 | 10:06 AM
Gouki133's Avatar
Default Re: (ryc555)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryc555 &raquo;</TD></TR><TR><TD CLASS="quote">you might have a busted speed sensor bro!
http://i54.photobucket.com/alb...1.jpg</TD></TR></TABLE>
is that expensive to replace?
also could it be anything else ?
Old Dec 13, 2006 | 10:27 AM
ryc555's Avatar
Default Re: (Gouki133)
try to go to some salvage garage near to your place...
or maybe try to check your overlay glows maybe there is a bubled surface that makes your niddle stock sometimes...
or maybe your cluster gauge that is busted...
but based on my experience usually the VSS or speed sensor is the one that cause speedometer niddle erratic function...
hbhonda
Oct 20, 2009 06:34 PM
krazieV
Aug 7, 2008 08:43 PM
shmack2004
Oct 1, 2006 06:40 PM
iblingidawg
Dec 17, 2005 11:18 AM
SpoonIntegra808
Nov 26, 2004 01:04 AM
