mph not working
i have a b16a2 in a 91 crx,my mph nor my odometer work.does anyone know what i should do to hook it up is there some kind of conversion or something i am missing?maybe i hooked it up wrong,what might the right way be?
ill have to check if its completely in with the clip,i had someone do the wiring for the dpfi to the mpfi and the conversion from obd0 to obd1 using a p72, he used a all the stuff from lo-cash racing(piggyback harness etc...)do you think it could have something to do with it??
I think but im not certain one time i had a fuse go out with something else on my rex...then my cluster wasnt working..replaced the fuse and it worked...
so does anyone know about the wiring (obd0 to obd1 and the p72)maybe being the problem cause my friend has the same problem in his 91 civic hb with an ls,same **** his dad did the wiring in both cars and hes not sure,what other things might i want to check on??
GPC91
11
Sep 12, 2012 07:33 AM
