? with install on ground control with koni yell sturts
Old Dec 12, 2006 | 02:49 PM
cullylude05's Avatar
Default ? with install on ground control with koni yell sturts
this weekend i put my ground contol in with koni struts and it said to put the top part of the bump stop from the opld strut on to the new strut and also to use the dust cover fronm the old strut and put in on the new strut ,to cover the strut rod, anyone do this and if so what did they do to do it, b/c the dust cover hole at the top will not fit over the new strut rod, so im thoinking of drilling a bigger hole, and the bump stop i guess u just slice it and maybe throw some tape or something, we didnt no how important it was and were running out of time so throw them on and toolk it off the lift and its just sitting at frinds shop and im trying to figure out if i neew to throwe this stuff on..
Old Dec 12, 2006 | 03:48 PM
avallach's Avatar
Default Re: ? with install on ground control with koni yell sturts (cullylude05)
Follow the instructions to the letter provided by the GC instructions. Cut/drill your bumpstop and dust cover to fit the Koni's. DON'T install the GC's without the bumpstops and dust covers! Your springs will end up cutting up the spring isolaters from the springs movement. Those things cost $15/less shipping each to replace.
Old Dec 12, 2006 | 03:58 PM
A Blue Lude's Avatar
Drilling out the stuff works fine. You don't have to remove too much material...
Old Dec 13, 2006 | 08:40 AM
i talked to the guys at ground control they said to just throw tjhe dust cover away and the koni strut came with a bump stop on it already but the guy said to get it off and cut all but the top inch . but im only going to drop the car an inch so thinking maybe i dont have to cut it off, cause we got the whole suspenasion on and now i got it just sitting at the shop waiting to c what to do
Old Dec 13, 2006 | 01:06 PM
avallach's Avatar
Default Re: (cullylude05)
I've heard that newer GC kit's may have a plastic/fiber-based spring isolators. If that's the case, you may be able to get away with NOT using the dust boot. If your isolators are made with that soft rubber material, use the dust boots. The springs easily dig into them and start ripping them apart. All of my four isolators got torn after driving on some fairly rough roads. The dust boot keep the isolators centered and prevents excessive movement.
Old Dec 13, 2006 | 01:57 PM
thanks man
ep3,lover
Jan 3, 2012 09:13 PM
Stopsign32v
Suspension & Brakes
Feb 16, 2011 05:06 AM
mistahmac
Sep 28, 2008 09:31 AM
corej87
May 19, 2008 11:13 PM
solo-x
Jan 26, 2003 07:36 PM
