civic ex spindles vs crx si spindles
Old Dec 12, 2006 | 02:12 PM
ef 4 door's Avatar
Default civic ex spindles vs crx si spindles
i wanted to know what the difference is between the civic ex and crx si spindles. I remember reading a topic that talks about a big brake upgrade with differnet parts from accords and preludes. but I was not sure with either the crx si or civic ex spindle?
Old Dec 12, 2006 | 02:13 PM
EL Vap133's Avatar
Default Re: civic ex spindles vs crx si spindles (ef 4 door)
90-91 EX spindle for big brake upgrades, the Si has the smaller brakes.
Old Dec 12, 2006 | 02:19 PM
ef 4 door's Avatar
Default Re: civic ex spindles vs crx si spindles (EL Vap133)
so go wit the 90-91 ex spindles. do they still use the same uca & lca? so do u know anything about the big brake upgrade?
Tyson's Avatar
90-91 civic 4dr EX (there was no EX 88-89) has the bigger brakes, identical to DA integras. the knuckle geometry is identical to the regular Si knuckle however, which makes it a better swap for the crx. but integra knuckles work fine too and have a bigger bearing also.
dont use any control arm from another car when swapping anything.
some pics are missing.
https://honda-tech.com/zerothread?id=1241022
no, i do NOT have any knuckles for sale.
and i think vap knows a lot about the big brakes. but we'd all like for you to search in the FAQ first.
Old Dec 14, 2006 | 11:02 AM
ef 4 door's Avatar
Default Re: civic ex spindles vs crx si spindles (Tyson)
thanx for the info, i will double check with faq on the brake section.
1net
Aug 18, 2008 06:16 PM
Declectic
Honda Civic (2006 - 2015)
21
May 5, 2006 04:55 PM
PhatHardy
Jan 8, 2003 10:03 PM
