Carbon canisters, swaps, and vaccum leaks, oh my!
Old Dec 12, 2006 | 02:08 PM
Nate047's Avatar
Default Carbon canisters, swaps, and vaccum leaks, oh my!
Okay HT, I need some help here:
My problem is this. In my 98 CX hatch, I have a 2000 B16A from a USDM Si w/wiring harness. I am pulling a code 14 now, and I believe it is because of my carbon canister situation.
I have a canister from a GSR, and because the inlet on the canister does not match the hoses from my Si swap, I have a vaccum leak which is causing the CEL.
I think the best way to solve my problem is to just track down a Civic canister. Do i need an Si specifically, or will any model Civic do? Also, can someone please help me find the correct part on http://www.hondaautomotiveparts.com? I don't really know which section the part would be in...
Or if you have a better suggestion, please bring it up!
Thanks!
EDIT: I already tried Jerry rigging an increasing size hose setup to eliminate the leak, which did not work.
Old Dec 12, 2006 | 02:13 PM
just Touge's Avatar
Dude, most people who tuck their bays take that thing out.
Old Dec 12, 2006 | 02:17 PM
Nate047's Avatar
Default Re: (TougeFerio)
I'm not gonna be doing a tuck at this point in time, so I need some info...
OR, if you can suggest a way which I can still pass emissions without the canister, please... I'm all ears!!
Old Dec 12, 2006 | 02:27 PM
just Touge's Avatar
Default Re: (Nate047)
Pic?
Old Dec 12, 2006 | 02:34 PM
Nate047's Avatar
unfortunately, no pix of the problem... car is in the shop right now...
What section on http://www.hondaautomotiveparts.com would I find the parts under?
Old Dec 12, 2006 | 04:12 PM
Nate047's Avatar
Default Re: Carbon canisters, swaps, and vaccum leaks, oh my! (Nate047)
ttt
Old Dec 13, 2006 | 02:23 PM
Nate047's Avatar
ttt need suggestions!
Old Dec 13, 2006 | 02:31 PM
Eran's Avatar
HT White Ops
http://www.slhondaparts.com/br...1-A00
There you go, my man.
Old Dec 13, 2006 | 02:38 PM
axtran's Avatar
the canister is required.
Old Dec 14, 2006 | 12:13 PM
Nate047's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">http://www.slhondaparts.com/br...1-A00
There you go, my man.</TD></TR></TABLE>
Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by axtran &raquo;</TD></TR><TR><TD CLASS="quote">the canister is required.</TD></TR></TABLE>
For emissions, yes... I have my tags, and teh car will be most likely only a weekend warrior by the time the next session comes around.
SO, please be more specific in your answer.
gamegomer
Appearance Build Threads
19
May 6, 2010 02:36 PM
gamegomer
May 3, 2010 04:59 PM
YoungMoneySi
Feb 5, 2007 12:58 PM
Nate047
12
Nov 6, 2006 05:20 PM
TheNasty0ne
25
Mar 7, 2004 10:59 AM
