Help! ITR control arm install!
Old Dec 12, 2006 | 01:43 PM
sicksiguy's Avatar
Default Help! ITR control arm install!
i have itr omni power drag suspension and i just got itr rear control arms but the control arms aren't fitting on my 99 si. they are about 1 1/2 inches to short. shouldn't they fit?
here are some pics:
Old Dec 12, 2006 | 01:45 PM
EK k kay's Avatar
Default Re: Help! ITR control arm install! (sicksiguy)
You should have done some research buying that stuff. None of it will work. 96-00 Civic rear lca's are longer than the rest of the integra/civic rear lca's.
Old Dec 12, 2006 | 01:50 PM
sicksiguy's Avatar
well i got them from password and they sell them saying they fit for my car.
Old Dec 12, 2006 | 01:54 PM
EK k kay's Avatar
Default Re: (sicksiguy)
Better get your money back then because they will not fit for sure.
Old Dec 12, 2006 | 01:56 PM
sicksiguy's Avatar
password is lying then: http://www.passwordjdm.com/pro...D=256
Old Dec 12, 2006 | 02:04 PM
B16b-EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicksiguy &raquo;</TD></TR><TR><TD CLASS="quote">password is lying then: http://www.passwordjdm.com/pro...D=256</TD></TR></TABLE>
Take a look for yourself...do they look like they fit? you should have gotten the Omni coilovers for your application 99si not an ITR and you should have gotten the LCA's for a 99si not an ITR...I have the same car and coilovers and i purchased my parts for my car and they look great and fit great too. Send them back and get your money or the proper replacement
Old Dec 12, 2006 | 02:10 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
wow u should have researcehed homey. dont know if they will take it back since it was installed already
Old Dec 12, 2006 | 02:12 PM
GG99's Avatar
Default Re: Help! ITR control arm install! (rukawa1one)
to be fair, password is falsely advertising them. get your money back yo
Old Dec 12, 2006 | 02:23 PM
MasterKwan's Avatar
Default Re: Help! ITR control arm install! (GG99)
"Here is a pair of original JDM DC Integra Type R Rear Lower Control arms! Perfect if you're looking to replace your stock suspension. This part will also fit any EF, EG, EK, and DA chassis.
Please note that this item will be AS IS only, no returns or exchanges. It may have some rust and/or worn bushings, etc"
Says no returns. I made the same mistake. Don't feel too bad. Brand new arms from Honda are only $100 (ITR or EK). You have them mounted upside down too. Open end goes to the bottom.
Old Dec 12, 2006 | 02:33 PM
sicksiguy's Avatar
the only problem is that the suspension is for a 94-01 ITR. the only reason i got it is because my friend had a type r but sold it and gave me the suspension real cheap. i even posted on here before and was told that all i needed was itr lcas. i'll talk to password though
Old Dec 12, 2006 | 03:35 PM
sicksiguy's Avatar
yeah for itr only. looks like i'm headed to honda market place
Old Dec 12, 2006 | 03:53 PM
.E's Avatar
.E
You have them installed upside down, not that it matters now since the ITR LCA's are not interchangable with 96-00 civic's
Old Dec 12, 2006 | 05:16 PM
rleonekc's Avatar
Default Re: (.E)
Yeah, that looks like it's not going to fit man...Get your money back while you still can, and get the part that you do need.
Old Dec 12, 2006 | 05:35 PM
NIKE SB'd's Avatar
Haha you learned the hard way EG/DC rear LCAs are NOT compatable with EK
Old Dec 12, 2006 | 05:50 PM
boostedintivic's Avatar
Default Re: (.E)
that sucked to bad it didnt work would have helped alot
ilovemyb16a
Aug 8, 2007 05:23 AM
gabebauman
Suspension & Brakes
Apr 27, 2007 05:50 AM
shyxboy
Apr 21, 2005 06:03 PM
Wuman
23
Mar 17, 2005 10:50 AM
awdriscol4
Suspension & Brakes
21
Mar 11, 2005 10:34 AM
