Suspension & Brakes Theory, alignment, spring rates....
Turn wheel and doesn't get traction, just burns tires
Old Dec 12, 2006 | 01:36 PM
DarkBB4's Avatar
Default Turn wheel and doesn't get traction, just burns tires
hey when im trying to take a turn hard in my prelude... It just squeals the tires and doesn't really get traction around turns... This is understeer correct?
how do i go about fixing this
205/50/15 nito 450rs
kyb agx
sprint lowering springs
stripped interior w/ jdm h22a
Old Dec 12, 2006 | 02:03 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Turn wheel and doesn't get traction, just burns tires (DarkBB4)
Stiffening up the rear end in relation to the front will make the car more prone to oversteer. This includes doing any combination of the following: Stiffer rear springs, stiffer rear sway-bar, stiffer rear shocks, softer front springs, softer front sway-bar, softer front shocks.
You can also modify the amount of traction to induce oversteer by doing any of the following: Skinnier rear tires, higher rear tire pressure, wider front tires, lower front tire pressure.
Your "free" options would be to disconnect one end-link on the front sway-bar (disables it completely), raise the rear tire pressure in 2psi increments, and lower the front tire pressure in 2psi increments. Making these changes can make the car dangerous & unpredictable, so be very careful when testing...
Old Dec 12, 2006 | 02:41 PM
DarkBB4's Avatar
Default Re: Turn wheel and doesn't get traction, just burns tires (94eg!)
haha i should have noted that i dont have a front or rear sway bar
have a rear strut bar tho
Old Dec 12, 2006 | 03:01 PM
nonsense's Avatar
The cure for understeer is to slow down .... no, really.
Old Dec 13, 2006 | 06:41 AM
02 accord's Avatar
Default Re: Turn wheel and doesn't get traction, just burns tires (nonsense)
http://en.wikipedia.org/wiki/Lift-off_oversteer
Try that one.
Old Dec 13, 2006 | 10:03 AM
Jpres927's Avatar
Default Re: Turn wheel and doesn't get traction, just burns tires (02 accord)
better tires
em96civicex
Feb 22, 2008 01:09 PM
dyu626
Honda Motorcycles
Nov 30, 2007 05:02 PM
Accord2K1
Nov 5, 2003 10:28 AM
vtec.dc2
Sep 26, 2002 10:18 PM
kkim
Apr 26, 2002 12:45 PM
