Where the heck is my shifting gauge in the cluster?
Old Dec 12, 2006 | 10:33 AM
EvenStar's Avatar
Default Where the heck is my shifting gauge in the cluster?
Ever since I started driving my 5th gen automatic Accord, I noticed that there is no shift meter (where it tells you whether your on P,R,D4,D3,etc.) and I always have to look down before going out to drive or when I shift from D3 to D4 on the freeway, I tend to forget so I have to look down quick (yes very dangerous). I know its suppose to be between the RPM and speedometer, but its blank between there. JDM SiR CD6 cluster??
Old Dec 12, 2006 | 11:03 AM
philadd's Avatar
Default Re: Where the heck is my shifting gauge in the cluster? (EvenStar)
Take a picture of your gauges... maybe someone changed it out with a 5 spd unit for some reason.
Old Dec 12, 2006 | 11:23 AM
Honda4lyf's Avatar
Ask the person you bought it from if you can contact him.
Old Dec 12, 2006 | 05:21 PM
EvenStar's Avatar
Default Re: Where the heck is my shifting gauge in the cluster? (Honda4lyf)
previous owner says it was like that and has no contact information from the first owner. im the third owner btw. does the CD6 SiR gauge come with the shift meter?
Old Dec 12, 2006 | 05:35 PM
TheMuffinMan's Avatar
He knows where you live!
If it was an automatic it would, I don't know why you woudn't have one. It should be square in the middle of the spedo and rpm's
Old Dec 12, 2006 | 06:15 PM
EvenStar's Avatar
Default Re: (TheMuffinMan)
nah, just a blank spot in between. i looked through it closely... no squares or anything.
Old Dec 12, 2006 | 11:44 PM
SuShiBoiiii's Avatar
Default Re: (EvenStar)
are you the second owner of this car'? probably it might have been replaced and you should run a carfax on that thing cuz tht odo might be way off
Old Dec 13, 2006 | 06:09 AM
Andryzzle's Avatar
Default Re: (SuShiBoiiii)
jdm cluster would be in km/h so you can check that right away unless you live in canada... im thinking somebody swapped a manual cluster into there. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuShiBoiiii &raquo;</TD></TR><TR><TD CLASS="quote">you should run a carfax on that thing cuz tht odo might be way off</TD></TR></TABLE>
EL2
Jul 3, 2019 09:26 AM
trinitycivic93
Jun 16, 2005 11:29 AM
josups
Dec 1, 2002 06:42 PM
allmotr1.8
Oct 27, 2002 07:03 PM
