Will I rub?
Old Dec 12, 2006 | 12:06 AM
DFW's Avatar
DFW
Default Will I rub?
Tires are 205/50/15 and rims are 15x7 with +43 offset. I'm tuckin' tire right now and rubbing with 195/55/15 on Si rims (not sure on the offset). Will I rub more, less or at all with the new tires and rims?
Old Dec 12, 2006 | 12:44 AM
old man neri's Avatar
Default Re: Will I rub? (DFW)
What car is this on?
If you are rubbing with 195/55-15s on Si rims then I am willing to bet you will rub with 205/50-15s on +43 rims.
Old Dec 12, 2006 | 12:46 AM
DFW's Avatar
DFW
Default Re: Will I rub? (old man neri)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri &raquo;</TD></TR><TR><TD CLASS="quote">What car is this on?
If you are rubbing with 195/55-15s on Si rims then I am willing to bet you will rub with 205/50-15s on +43 rims.</TD></TR></TABLE>
00 civic. I'm rubbing the inner part of the fender, not the outside right now.
Old Dec 12, 2006 | 08:38 AM
nsxtasy's Avatar
H-T Order of Merit
Your problem must be your offset (and possibly your wheel width), not your tire size. With the proper offset, 195/55-15 tires should not rub on a 2000 Civic. Even if it's lowered.
I don't understand how you can be rubbing with 195/55-15 tires on Si rims...
Old Dec 12, 2006 | 10:56 AM
vtecsi00's Avatar
Default Re: Will I rub? (nsxtasy)
si have a 15x6.5 with a 45mm offset...your new wheels are going to cause it rub even more
Old Dec 12, 2006 | 12:42 PM
nsxtasy's Avatar
H-T Order of Merit
I didn't mean to doubt what you say, but rather, to note that there must be something wrong to have them rub. From vtecsi00's post, it sounds like the offset on those wheels makes them unsuitable for your car.
Old Dec 12, 2006 | 01:08 PM
HeyMikeyyyy's Avatar
just go with some 195/50s and u will be happy with it from +10 offset to 55 offset ur good to go!!!
Old Dec 12, 2006 | 02:20 PM
ATS*VEEE's Avatar
Default Re: Will I rub? (HeyMikeyyyy)
word...im runnin 195/50 on a 15x7 +42...
Old Dec 12, 2006 | 02:24 PM
DFW's Avatar
DFW
Default Re: Will I rub? (one^VEEE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by one^VEEE &raquo;</TD></TR><TR><TD CLASS="quote">word...im runnin 195/50 on a 15x7 +42... </TD></TR></TABLE>
I just might switch tires. We'll see if I end up getting them. Thanks guys.
Old Dec 12, 2006 | 02:26 PM
FalkenSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">I didn't mean to doubt what you say, but rather, to note that there must be something wrong to have them rub. From vtecsi00's post, it sounds like the offset on those wheels makes them unsuitable for your car.
There's nothing wrong, maybe he's slammed. Even if he uses the right wheel/tire combo, if he's really slammed, then yeah, it's very possible.
Old Dec 12, 2006 | 03:40 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Will I rub? (J.MONEY)
Even a 2000 Civic that is significantly lowered should have no rubbing with 195/55-15 (or 205/50-15) tires, as long as the wheels are the proper offset. There's no reason to use undersized 195/50 tires on a 2000 Civic (although they're the proper size for pre-'96 Civics). When you have one problem, don't make a mistake by adding another problem on top of it; instead, fix the original problem.
Old Dec 12, 2006 | 03:53 PM
r.wright's Avatar
i say get tiny wheel spacers or the correct size wheel since you seem to be hella lowered. 15x6.5 or 15x7 +38 may do the trick if you really need the extra width of the 7" rim and are scared of rubbing the insides.
Old Dec 12, 2006 | 05:12 PM
vtecsi00's Avatar
Default Re: Will I rub? (mrrlx)
15x7 with a 35mm offset would be ideal
Old Dec 12, 2006 | 06:12 PM
hasback*'s Avatar
F*CK THIEVES!
Default Re: Will I rub? (vtecsi00)
i told u.get 195/50s!!! lol
Old Dec 12, 2006 | 06:30 PM
hasback*'s Avatar
F*CK THIEVES!
Default Re: Will I rub? (hasback*)
oh yea.dont be cheap. buy some! lol
Old Dec 12, 2006 | 06:36 PM
DFW's Avatar
DFW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hasback* &raquo;</TD></TR><TR><TD CLASS="quote">i told u.get 195/50s!!! lol </TD></TR></TABLE>
These are new rims
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hasback* &raquo;</TD></TR><TR><TD CLASS="quote">oh yea.dont be cheap. buy some! lol </TD></TR></TABLE>
hahah
Old Dec 16, 2006 | 09:51 AM
vtecsi00's Avatar
did those springs come that way from ground control???? those spring's look like they are for a nissan on the fronts and the rears are for a honda...i would have to say that your springs are the problems.................
Old Dec 16, 2006 | 09:54 AM
DFW's Avatar
DFW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecsi00 &raquo;</TD></TR><TR><TD CLASS="quote">did those springs come that way from ground control???? those spring's look like they are for a nissan on the fronts and the rears are for a honda...i would have to say that your springs are the problems.................</TD></TR></TABLE>
I've seem them before on other Hondas, but never got a real response from the owners. I bought these used. I emailed Ground Control the same picture and they never responded.
lechuza05
Apr 25, 2006 01:47 PM
DsBananas94LS
Sep 29, 2005 01:43 PM
hnz28sjz
Jul 30, 2005 04:56 PM
EMphaticONE
17
Dec 15, 2004 06:45 AM
mark smith
Oct 3, 2003 06:24 AM
