FS: HASPORT MOTOR MOUNT FOR EF EK EG DC2 etc................................ JDMRobot
Brand new EGK1 HASPORT MOTOR mount K-series swap into...
*1992-1995 Honda Civic
*1994-2001 Acura Integra
[IMG]
[/IMG]
Bolt the K-Series mount kit into your 92-95 Civic or 94-01 Integra. Take advantage of Honda's newest creation the K-series. Your gonna need these mounts if you want to drop a K-series in your EG or DC2/DB8. Made of a lightweight ultra strong T-6061 aluminium these mounts have a lifetime warranty. Engine movement is minimized by controlling the durometer of the polyurethane bushings, and as such, only 3 mounts are required.
* CAD/CAM Designed.
* Proper engine placement and axle alignment.
* 6061 T-6 aluminum.
* 62A, 70A, 80A urethane.
[B]Asking $600
[IMG]
[/IMG] Bolt the K-Series mount kit into your 92-95 Civic or 94-01 Integra. Take advantage of Honda's newest creation the K-series. Your gonna need these mounts if you want to drop a K-series in your EG or DC2/DB8. Made of a lightweight ultra strong T-6061 aluminium these mounts have a lifetime warranty. Engine movement is minimized by controlling the durometer of the polyurethane bushings, and as such, only 3 mounts are required.
* CAD/CAM Designed.
[B]Asking $600
Brand new HASPORT MOTOR mount to swap a K-series into...
1996-2000 Civic
[IMG]
[/IMG]
This mount is require for a k-series swap into 96-00 Civic. Made of a lightweight ultra strong T-6061 aluminium these mounts have a lifetime warranty. Engine movement is minimized by controlling the durometer of the polyurethane bushings, and as such, only 3 mounts are required.
* CAD/CAM Designed.
$600
1996-2000 Civic
[IMG]
[/IMG] This mount is require for a k-series swap into 96-00 Civic. Made of a lightweight ultra strong T-6061 aluminium these mounts have a lifetime warranty. Engine movement is minimized by controlling the durometer of the polyurethane bushings, and as such, only 3 mounts are required.
* CAD/CAM Designed.
$600
BRAND NEW DCSTK HASPORT replacement mount kit for.......
1993-1997 Del Sol
This mount is to replace your stock 92-95 Civic, 1993-1997 Del Sol or 1994-2001 Integra mount. Made of a lightweight ultra strong T-6061 aluminium these mounts have a lifetime warranty. Engine movement is minimized by controlling the durometer of the polyurethane bushings.
* CAD/CAM Designed.
Asking for $380
Modified by JDMRobot714 at 10:29 AM 2/1/2007
1993-1997 Del Sol
* CAD/CAM Designed.
Asking for $380
K-all-day
Mar 20, 2011 12:47 AM
JDMtransformer
Jan 5, 2007 03:28 PM
ADVAN JDM
Apr 20, 2004 10:26 AM
