H22 Adjustable Cam Gears, which isn't prone to breaking
Old Dec 11, 2006 | 09:14 PM
bb_one's Avatar
Default H22 Adjustable Cam Gears, which isn't prone to breaking
Hey guys,
I've search the forums, but I haven't really found anything conclusive.
I always dreaded those adjustable cam gears in fear of slippage or the worse, breakage. I have seen a set of Golden Eagle cam gears break on a b-series which left the guy with a bunch of bent valves on a built head.
I really would like to avoid it at all costs, but since I am turbo'd, dialing out the overlap would be able to help me make some moderate gains and help with efficiency.
So the question stands, what adj. cam gears have you guys used that seems to hold up well. I've only really looked into the Skunk2 gears (not the pro series), any thoughts?
Old Dec 11, 2006 | 09:27 PM
Hondaholik's Avatar
Default Re: H22 Adjustable Cam Gears, which isn't prone to breaking (bb_one)
i had AEM on my H, worked very good
Old Dec 11, 2006 | 09:48 PM
94Vtecluder's Avatar
Default Re: H22 Adjustable Cam Gears, which isn't prone to breaking (Hondaholik)
With most of the aftermarket ones I've seen the problem has been due to overtorquage of the gears, so I'd say a proper install is your biggest concern. Also you might want to post this in the all motor section since this is a sort of general question and there are a lot more gearheads over there with relevant info/personal experiences.
Modified by 94Vtecluder at 3:34 AM 12/12/2006
Old Dec 11, 2006 | 09:52 PM
bb_one's Avatar
Default Re: H22 Adjustable Cam Gears, which isn't prone to breaking (94Vtecluder)
Yea, I've read up on a few threads concerning that, it does make sense, since most of these aftermarket ones are made of aluminum.
However I'd still like to see what most people are running and how their impression of the gears are in long term useage.
Old Dec 11, 2006 | 10:05 PM
md23vtec's Avatar
AEM (3bolts) works for me on my turbo car. I have skunk2(6 studs) on my nitrous car. IMO if you know how to tighten them correctly you will not have any problems
Old Dec 12, 2006 | 05:13 AM
InvaderTrax's Avatar
The AEM 3 bolt was the one that most people complained about slippage. That's why you generally look for 4 or more bolts. They even make them with 7 now (overkill)
Old Dec 12, 2006 | 05:17 AM
BB2H22's Avatar
X's 2
5 Bolt
Old Dec 12, 2006 | 06:19 AM
577HondaPrelude's Avatar
Default Re: H22 Adjustable Cam Gears, which isn't prone to breaking (BB2H22)
I have not use their cam gears but I know they make good stuff:
http://shop.mfactoryhk.com/pro...Gears
Old Dec 12, 2006 | 06:56 AM
PrecisionH23a's Avatar
Default Re: H22 Adjustable Cam Gears, which isn't prone to breaking (577HondaPrelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 577HondaPrelude &raquo;</TD></TR><TR><TD CLASS="quote">I have not use their cam gears but I know they make good stuff:
http://shop.mfactoryhk.com/pro...Gears</TD></TR></TABLE>
Those are the same cam gears that a ton of companies rebadge their name on.
I run AEM 5 bolts on the majority of set-ups that we do. I have used the Skunk2's also flawlessly in the past.
Old Dec 12, 2006 | 07:09 AM
bb_one's Avatar
Default Re: H22 Adjustable Cam Gears, which isn't prone to breaking (PrecisionH23a)
That's what I needed, thank you.
Old Dec 12, 2006 | 08:15 AM
md23vtec's Avatar
Default Re: (InvaderTrax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax &raquo;</TD></TR><TR><TD CLASS="quote">The AEM 3 bolt was the one that most people complained about slippage. That's why you generally look for 4 or more bolts. They even make them with 7 now (overkill)</TD></TR></TABLE>
Installation error IMO
Old Dec 12, 2006 | 08:57 AM
mgags7's Avatar
I have yet to ever hear a complaint about JUN gears....6 bolt ftw
Old Dec 12, 2006 | 09:04 AM
Revi's Avatar
Default Re: (bb4ever)
Not to throw a curve ball in this thead but do you guys think i would benefit from cam gears? Other wise, with type-s cams? Im debating on getting cam gears because i dont know if i would benefit from them.
Old Dec 12, 2006 | 09:10 AM
mgags7's Avatar
If you get someone to put your car on a dyno and try tuning them I bet you could pick up a some power.....not an incredible amount but definitely something....
Old Dec 12, 2006 | 10:08 AM
Mykizism's Avatar
tuning came gears in is a pita... thats why i opt for oem cams gears OOPSS! haha
Modified by Mykizism at 2:16 PM 12/12/2006
Old Dec 12, 2006 | 10:24 AM
md23vtec's Avatar
Default Re: (Mykizism)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mykizism &raquo;</TD></TR><TR><TD CLASS="quote">tuning came gears in is a pita... thats why i opt for oem cams </TD></TR></TABLE>
You can still dial in OEM cams with cam gears
Old Dec 12, 2006 | 11:17 AM
Mykizism's Avatar
Default Re: (md23vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by md23vtec &raquo;</TD></TR><TR><TD CLASS="quote">
You can still dial in OEM cams with cam gears </TD></TR></TABLE>
cam gears! LOL OOPS
Old Dec 12, 2006 | 06:36 PM
AllMotorRandy's Avatar
Golden Eagle Mfg. 4 bolt cam gears are working great for me. They look baller too! You can get them here ---&gt; camp1320.com
Old Dec 12, 2006 | 06:52 PM
Flip.'s Avatar
Default Re: (AllMotorRandy)
Would anyone recomend getting adj. cam gears with stock cams?
so_vayne
Dec 11, 2018 11:36 AM
EGtypeR408
May 28, 2011 05:05 PM
nogutsnoglory77
Aug 24, 2007 08:18 AM
DETOUR180
66
Aug 29, 2005 02:00 PM
