Do You Guys Ever Find Any Stuff On Your Magnetic Oil Pan Drain Plugs ?
Old May 11, 2002 | 12:50 PM
JSIR's Avatar
New User
Default Do You Guys Ever Find Any Stuff On Your Magnetic Oil Pan Drain Plugs ?
I've been using the magnetic oil pan drain plug for a couple oil changes (one of the cheapo ones). I don't get much accumulation on it between changes. I get some ultra-fine metal that clings to the magnet, it is so fine that it almost has the consistency of a paste when your rub it between your fingers, can't even feel it. A very tiny , tiny amount. Anyone else find anything on theirs ?
Joey
Old May 11, 2002 | 12:56 PM
Cosworth's Avatar
Default Re: Do You Guys Ever Find Any Stuff On Your Magnetic Oil Pan Drain Plugs ? (JSIR)
Yes, very, very tiny black magnets.
Old May 11, 2002 | 01:06 PM
RagingAngel's Avatar
Default Re: Do You Guys Ever Find Any Stuff On Your Magnetic Oil Pan Drain Plugs ? (Cosworth)
SnyperSiR usually finds tons on his drain plug....but then not many people have extended drain intervals in the double digits!
I also use a filtermagnet to keep things locked down....
Old May 11, 2002 | 01:10 PM
JSIR's Avatar
New User
Default Re: Do You Guys Ever Find Any Stuff On Your Magnetic Oil Pan Drain Plugs ? (RagingAngel)
well last oil change I ran 5w-30 Castrol, this oil change I am running 10w-30 Castrol Syntec Blend , should be interesting to see if there is any difference in the appearance of the drain plug, my driving habits are pretty consistent too.
Joey
whytetygerwolf
18
May 27, 2014 05:56 PM
NOOdS
13
Nov 28, 2011 02:56 PM
RFP-DA9
Sep 7, 2007 03:32 PM
SamC
Apr 11, 2006 01:21 PM
RCautoworks
Jan 4, 2003 01:11 PM
