back runnin (kinda)
Old May 11, 2002 | 11:45 AM
zCivic's Avatar
Default back runnin (kinda)
I got my teg ECU to start and run. Its still throwing the code 10, 13, and 9. Tested everything and everything checks out fine. The only thing left from the Helms is new ECU. I tested the ECU in my friends 90 DX with a ZC (mine is a Z6 swap) but it didn't throw any codes in his car so the ECU is good what else can cause my problems???
Old May 11, 2002 | 11:59 AM
CimorelliCRX's Avatar
Default Re: back runnin (zCivic)
#9-Cylinder Position Sensor - Check your wiring to the distributor, maybe you crossed some wires... What did you have, a DX or SI?
#10-Intake Air Temporature - Its a sensor, you should have an extra wire on the back of the block. Maybe you dont have that one hooked up right, thats the one that people get confused on...
#13-BARO Sensor - I dont know how that works, I had this code when I ran my ZC at first, but I reset the computer and all the codes went away.
Dont know if this helped... Only one I would worry about at all is the #9, you have a wire messed up or something it sounds like.
jweeks
May 2, 2009 08:08 AM
the.hamburglar
Jul 29, 2004 07:44 PM
rschoener
Aug 17, 2003 08:48 AM
Ronin Panda
May 13, 2003 02:29 PM
racedoutsi
Mar 29, 2002 08:00 AM
