Where is the switch for an EM1/B16 FAN?
Old Dec 11, 2006 | 05:58 PM
Nameless Warrior's Avatar
Default Where is the switch for an EM1/B16 FAN?
Where is the fan switch located for an EM1/B16.
My fan is not working so I am wondering if its Thermostat or the switch.
Old Dec 11, 2006 | 06:06 PM
my_slow_civic's Avatar
Default Re: Where is the switch for an EM1/B16 FAN? (Nameless Warrior)
Underneath the distributor.
Oops, that is the temo gauge.
Modified by my_slow_civic at 9:00 PM 12/11/2006
Old Dec 11, 2006 | 06:12 PM
Default Re: Where is the switch for an EM1/B16 FAN? (my_slow_civic)
Do you have a picture of it? What exactly does it look like?
Old Dec 11, 2006 | 06:18 PM
kai-chun's Avatar
switch is 11, thermostat is 3
Old Dec 11, 2006 | 06:22 PM
Default Re: Where is the switch for an EM1/B16 FAN? (kai-chun)
So how do I check if the fan is working? I need to find out if its the fan or the swithc I need to replace. Thank!
Old Dec 11, 2006 | 06:34 PM
Old Dec 11, 2006 | 07:06 PM
Kista20's Avatar
jump the two wires together on the switch and if it turns on then the switch is bad.
Old Dec 11, 2006 | 07:16 PM
Default Re: Where is the switch for an EM1/B16 FAN? (Kista20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kista20 &raquo;</TD></TR><TR><TD CLASS="quote">jump the two wires together on the switch and if it turns on then the switch is bad.</TD></TR></TABLE>
Sorry to be an idiot but how the heck are u suppose to do that?
Old Dec 11, 2006 | 07:51 PM
Kista20's Avatar
use either a paper clip or a wire will do the trick, you just have to get the two wires connected to each other.
Old Dec 11, 2006 | 08:06 PM
THANKS!
Old Dec 12, 2006 | 01:37 PM
I forgot to mention my motor is a JDM B16A first gen. So, I was told it was an OBD0. Where would the fan switch be located on an OBD0 JDM B16A first gen?
Old Dec 12, 2006 | 03:03 PM
EK FLY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nameless Warrior &raquo;</TD></TR><TR><TD CLASS="quote">I forgot to mention my motor is a JDM B16A first gen. So, I was told it was an OBD0. Where would the fan switch be located on an OBD0 JDM B16A first gen?</TD></TR></TABLE>
same ****
Old Dec 12, 2006 | 03:06 PM
Default Re: Where is the switch for an EM1/B16 FAN? (super-hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super-hatch &raquo;</TD></TR><TR><TD CLASS="quote">
same ****</TD></TR></TABLE>
Really..?
I read somehwere on here that it's located somewhere else.
Damn alot of misinfo on here.
Old Dec 12, 2006 | 03:07 PM
HondaPartsHero's Avatar
Technical Hero
actually isn't the fan switch on the back of the block on a first gen b16 like a 90-91 LS integra?
Old Dec 12, 2006 | 04:03 PM
Default Re: Where is the switch for an EM1/B16 FAN? (HondaPartsHero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaPartsHero &raquo;</TD></TR><TR><TD CLASS="quote">actually isn't the fan switch on the back of the block on a first gen b16 like a 90-91 LS integra?</TD></TR></TABLE>
Yes, it should be on the back, and have two pins coming out of the sensor.
If your block was replaced, chances are, they did not even hook up the sensor for the fan.
Old Dec 12, 2006 | 04:39 PM
Kista20's Avatar
I've seen quite a few people that when the switch goes bad they will just wire in a toggle switch to bypass it but if it was me I would replace it and do it right.
Old Dec 13, 2006 | 07:19 AM
So can someone confirmed if the switch is near the thermostat housing or behind the block near the oil pan!??!
Du_Ma
Jun 14, 2003 12:19 PM
riceball777
Apr 29, 2003 12:40 AM
