how much and where to get a roll cage?
Old Dec 11, 2006 | 02:39 PM
Speed Infliction's Avatar
Default how much and where to get a roll cage?
just like the title says where and how much did you get it for. i am interested in it because i will probably need it for the track.
Old Dec 11, 2006 | 03:12 PM
ZygSpeed's Avatar
Default Re: how much and where to get a roll cage? (Speed Infliction)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed Infliction &raquo;</TD></TR><TR><TD CLASS="quote">... i am interested in it because i will probably need it for the track.</TD></TR></TABLE>
Roadcourse or drag strip?
Old Dec 11, 2006 | 03:13 PM
Default Re: how much and where to get a roll cage? (zygspeed)
dragstrip
Old Dec 11, 2006 | 03:20 PM
ZygSpeed's Avatar
Check the Summit Racing catalog or give them a call.
http://www.summitracing.com/
Old Dec 11, 2006 | 03:25 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed Infliction &raquo;</TD></TR><TR><TD CLASS="quote">dragstrip</TD></TR></TABLE>
Are you sure you need it for an 18 second quarter mile? (just reading your sig).
Autopower makes a nice rollbar. Their full cage (and any pre-bent cage) will leave something to be desired, but should be good enough. Considering the likelyhood of an incident (very low), and the penalty of the weight (high), you'll probably want the lightest thing that will get you buy.
For a road-racing car I care a lot less about weight, since minimum weights are set and usually high enough that you can afford some lbs on a cage.
-Chris
Old Dec 11, 2006 | 04:44 PM
doood's Avatar
been there done that
Default Re: how much and where to get a roll cage? (Chris F)
the best cage is one custom built for you car
Old Dec 11, 2006 | 04:53 PM
JDM Like Whoa's Avatar
Default Re: how much and where to get a roll cage? (that one doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by that one doood &raquo;</TD></TR><TR><TD CLASS="quote">the best cage is one custom built for you car </TD></TR></TABLE>
Agreed.
Autopower would be your next best bet.
Their fitment is
Ficky
31
Apr 23, 2008 08:09 AM
SItimSI
Sep 26, 2007 06:03 PM
rollingCULTURE
24
Jan 6, 2006 02:43 PM
h22blazerz5
May 15, 2004 06:57 PM
