Cant find my SMOG PLUG???.....Please Help.......
Old Dec 11, 2006 | 02:28 PM
jaydm ferio's Avatar
Default Cant find my SMOG PLUG???.....Please Help.......
I went to get my car smogged today, and they were unable to find the plug that they plug into(on my vehicle). I have a 2000 honda civic. I took apart my pannel under the steering wheel, but i couldnt find the plug. Is there another location where this plug can be placed? I need to get a smog asap.
Thanks for your help.
Old Dec 11, 2006 | 02:45 PM
jtchinoy's Avatar
Would the plug for plugging a troubleshooting device in to your car also be the smog plug? If so, check the right back side of your center console. There should be a grey plug back there, might be it.
Old Dec 11, 2006 | 02:59 PM
Default Re: (jtchinoy)
Does anyone know where the "smog plug" comes from? Can I trace it back to the main wire harness?
Old Dec 11, 2006 | 03:10 PM
tha_badguy's Avatar
where did you go
sounds like you went to a shithole
Old Dec 11, 2006 | 03:13 PM
vltnolia's Avatar
its around the driver side area
Old Dec 11, 2006 | 03:37 PM
EgSalad's Avatar
Default Re: Cant find my SMOG PLUG???.....Please Help....... (jaydm ferio)
If they (smog shop) couldnt find your obd2 plug in, which is on the drivers side kinda close to the hood release, then they didnt know what they are doing & you should go somewhere else where they have a clue.
Old Dec 11, 2006 | 05:06 PM
Default Re: Cant find my SMOG PLUG???.....Please Help....... (EgSalad)
I took off the pannel and looked for myself, its not there. Maybe its tucked in or something, im not sure. Do cars from mexico,us,canada,japan all have them in the same spot?
Also is there a way for me to follow the wires and find it? What part of the car does the plug come from?
Old Dec 11, 2006 | 06:08 PM
Luserkid's Avatar
No offense but do you know what your looking for? Like have you seen one before?
Old Dec 11, 2006 | 06:30 PM
Default Re: Cant find my SMOG PLUG???.....Please Help....... (Luserkid)
yea I know where it is located, But it's really strange on this car. Its not on the driverside, is there any way that it can be located behind the glove box?
Thanks for the diagram bro
Old Dec 11, 2006 | 06:32 PM
Is there anyway that the data link connector (16p) (Shown above) be removed?
Old Dec 11, 2006 | 06:33 PM
-JSpecEk*9-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydm ferio &raquo;</TD></TR><TR><TD CLASS="quote">yea I know where it is located, But it's really strange on this car. Its not on the driverside, is there any way that it can be located behind the glove box?
Thanks for the diagram bro </TD></TR></TABLE>
No!! damn
Old Dec 11, 2006 | 07:51 PM
Default Re: Cant find my SMOG PLUG???.....Please Help....... (JDMEK-9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMEK-9 &raquo;</TD></TR><TR><TD CLASS="quote">
No!! damn </TD></TR></TABLE>
Huh??
Old Dec 11, 2006 | 08:04 PM
EvilPhu's Avatar
If it's not under the dash, and not the passenger side near the center console, then someone must have moved. Did you have an alarm installed, maybe they moved it.
Old Dec 12, 2006 | 01:45 PM
Default Re: Cant find my SMOG PLUG???.....Please Help....... (EvilPhu)
Where does that plug come from? I know what it looks like but i need to know where it comes from so that i can try to follow the wires and find the plug. Thanks
Old Dec 12, 2006 | 02:14 PM
Kista20's Avatar
the plug on mine is right there in the pic... it's brown and is facing downwards so you have to crawl under there and look up. I thought there was a federal law that states that the plug has to be in the vicinity of the steering column meaning it can only be but so far from it. Sounds like someone moved it and if they did it can't be so far and look for the brown plug.
Old Dec 12, 2006 | 02:49 PM
parasonic's Avatar
Look within six inches of the hood release. It's hidden behind the gray panel. The connector is black and "points downward." It is WELL to the left of the steering wheel. There is a metal tab that it comes down from, I believe, D-shaped, with a rectangle in the middle of the D. The connector should fit in the rectangle!!
parasonic's Avatar
Default Re: Cant find my SMOG PLUG???.....Please Help....... (parasonic)
Sorry, the connector may be gray. My scangauge plugs into it and has a black connector
Old Dec 12, 2006 | 05:40 PM
Kista20's Avatar
regardless of color it still has to be basically right under the column and if I'm not mistaken it's 3 inches to the left or to the right.
beatthisspeed69
Jan 4, 2008 10:40 PM
anht
Dec 16, 2007 05:34 PM
pete_07
Audio / Security / Video
Jul 2, 2007 10:53 AM
NtegraRacR05
May 6, 2004 01:46 PM
