fast crx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec4lyfe »</TD></TR><TR><TD CLASS="quote">no one cares
If you don't have better things to say. hmmmm...Just STFU!!
Shut up D-bag.
Quick little car.
Shut up D-bag.
Quick little car.
/yourself
Nice vid, sick car
/yourself
Nice vid, sick car
He is a local here in tulsa. He owns Humble performace.
i was there for the 9.58 pass. That beast is amazing
Specs-
85 bore gsr 87 gsr crank 9.0 compression
GE sleeves, Je pistons coated, Crower rods, coated bearings ,
Head
Gsr full ferrea springs, retainers ,and over size valves, coated combustion camber, mild port and valve job, type r cams..arp head studs
Transmission
Gsr Hydro stock gear set with quaife, Competition clutch twin disk with pro drive stage 1 axles and outer hubs
Turbo set up
Revhard custom kit
T61 custom spec a/r generous size frount mount custom pipping, 3 inch down pipe etc Ge Intake manifold Bdl throttle body , custom fit c and r radiator,Custom Boost setup using quad stage from turbo xs
fuel system
custom bosh sump with -8 lines going to ge fuel rail topped off with 1000cc precision injectors, and venom fpr Msd ignition with 2 step and blaster coil. Fast engine management.
Chassis,
energy suspension bushings all 4 corners, tockico iluminas, and skunk drag coilovers, custom alignment, with z10 radius rod set up with custom solid frount mount, nhra legal 8 point cage, with all safety requirements for 9 second e.t.'s
harness, extened wheel studs, Ge scatter sheild ,parachute mount etc. The whole chassis has been welded in select places for extra strength, car was built for a beating.
Interior
Sparco sprint seats, sparco ring steering wheel, clean blue interior, autometer guages, Big tach with shift light, boost, oil pressure, egt, etc,
20 percent tint
Exterior
Mb fiberglass hood " looks Stock"
Custom blue paint, clean body ,Front 13X8.5 bogarts 24.5X9 mickey thompson slicks Rear 15X4 bogarts 24 morroso ds2 tires
Specs-
Head
Transmission
Turbo set up
Revhard custom kit
fuel system
Chassis,
Interior
20 percent tint
Exterior
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_DC4_Fanatic »</TD></TR><TR><TD CLASS="quote">"you know you owe me a 10 second car" LOL
Thats one badass rex
that'll rape torettos car, since it's a 9 second car
</TD></TR></TABLE>that'll rape torettos car, since it's a 9 second car
